Question about Magic Chef CGR3730 Gas Kitchen Range
Slow heating- low gas to burner
When turning oven on it takes about 90 seconds or more for burner to light. Takes 45 min for oven to heat up to 350 degrees. Cannot hear gas coming into oven, burner is lit but with very weak flame. Broiler unit seems to be working fine. magic chef cgr3760adb
  • gski69 May 18, 2009
    Tube is clean.
    Tube is clean.
  • 68 Answers
The main solution of it is to clean the gas tube.
Posted on May 18, 2009
  • Aldrin May 19, 2009
    Try the inner tube,there's a bronze tube inside maybe there's some particles blocks the gas.
Will not fully heat to temp setting; takes 2 min B4 gas ignition 2 heat.
Time for the gas valve to open fully can be a few minutes, I've seen them take up to 3 minutes to open, so its not unusual. Hoverer, the temp issue may be due to your burner's gas jets being clogged with ash, etc. Remove the burner and inspect, the holes or jets should be nice and clear, any clogged ones need to be opened use a safety pin or something similar to open, try no to make the hole any bigger then it is. You may also find it may light quicker since there will be less back pressure in the line once the jets are cleaned.
Aug 15, 2014 | Maytag MGR4452BDW / MGR4452BDQ /...
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Oven takes FOREVER to pre-heat
You probably have a bad heating element. Trip the breaker and make sure that all power is removed from the stove/oven. Remove the element, and test it for continuity. If it tests open, obtain a replacement from an appliance parts supply house. If it tests good, you should suspect either a bad switch or thermostat.
Regards, --W/D--
Jul 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Oven Burners not lighting completely
It's the igniters. They increase in resistance as the elements age and decreases the current required to heat the spring element in the gas valve.
Replace both igniters.
Dec 23, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Oben takes half an hour to heat up
I doubt its the igniter. It could be a faulty gas valve or maybe the orifice is blocked, and not letting enough gas into the burner
Jan 28, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
GE RANGE MODEL #JGBP35BEA2BB
Sounds like that ignitor is weak.  When the ignitor glows it builds up resistance to the gas valve for gas to come in.  If it sometimes takes 10 min then the proper resistance isn't there and this will give you that gas smell.  Replace the ignitor and this should solve your problem.  Can expect to pay $80 - $100 for the part.
Oct 14, 2007 | Kitchen Ranges
Oven takes a very long time to heat.
Do your burners work ok when the oven is on? if not you may have low supply pressure to your range or the regulator may be limiting the gas flow. Also, I have a wolf gas range and it takes 30 minutes to heat to 350 as well, haven't timed it to 400. Has it always taken that long? Another thing to check is the door seal. If its not sealing it could cause a long preheat. If the door seal is smashed flat and/or not soft it needs replaced. Hope this helps.
Dec 16, 2006 | GE Spectra JGBP30 Gas Kitchen Range
Magic Chef CGR3730 Gas Kitchen Range Logo
485 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
