Question about WMF Coffee Makers & Espresso Machines
Error 187 showing code 187 when Prestolino machine is turned on
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Descale
Posted on Dec 29, 2013
My wmf prestolino displays error code 187 when i turn it on. What does this mean ?
change the termistor from the top of the biger boiler with NTCM 10 ohm and that is the best solution 100% works
Nov 19, 2013 | WMF Coffee Makers & Espresso Machines
What does e 62 error code refer to?
E62: Overheating during washing this is real ans now iam giving u more tips abt error -
E11: Difficulty in filling during wash phase
E13: Water leakage.
E21: Difficulties in draining .
E23: Malfunction of drain pump triac.
E24: «sensing» circuit of the component (triac) that controls the drain pump faulty
E33: Incongruence between closure of anti-boiling and 1st level contacts of pressure switch
E35: Water level too high
E36: «sensing» circuit of anti-boiling pressure switch faulty
E37: «sensing» circuit of 1st level pressure switch faulty
E39: "HV" «sensing» circuit of anti-overflow pressure switch faulty
E40: Door open, Interlock, wiring or main PCB
E41: Door open
E41: Problems with aperture of door
E42: Problems with aperture of the door
E43: Problems with the triac which actions the door interlock
E44: Door closure «sensing» circuit faulty
E45: Problems with the «sensing» circuit of the triac that actions the door interlock
E51: Motor power triac short-circuited
E52: No signal from the motor tachymetric genetaror
E52: No signal from the tachymetric generator
Procedure for checking commutator motors
E53: Problems with the «sensing» circuit of the triac which powers the motor
E54: Motor relay contacts sticking
E61: Insufficient heating during washing
E66: The contacts of the heating element power relay are always closed
E71: NTC washing sensor faulty.
E82: Error in reading the RESET/OFF position of the programme selector.
E83: Error in reading the programme selector code
E93: Incorrect machine configuration.
E94: Incorrect configuration of washing cycle
E95: Communications error between microprocessor and the EEPROM
E96: Incongruence between control panel version and configuration data
E97: Incongruence between selector version and configuration data
EA1: Drum positioning system (DSP) faulty (top-loaders only)
EB1: Incorrect mains frequency
EB2: Mains voltage too high
EB3: Mains voltage too low
E32 INCORRECT CALIBRATION OF ANALOGIC (ELECTRONIC) PRESSURE SWITCH. IF THE MACHINE IS DRAINING OK, THEN IT IS THE SWITCH
E32 relates to the electronic pressure switch, normal pressure switch,inlet valves,poor water mains pressure and finally the main control board
E90 means theres a fault on the main control module so A;will need a new control module or B; get an engineer to try re-configureing the module
May 16, 2011 | Hoover Washing Machines
Call of Duty: B... »
update your console to newer firmware
Feb 27, 2011 | Microsoft Xbox 360 Console
I have forgotten my e63 lock code and was told to flash it. So after doing that i was told the lock code would be the dificult lock code. As in 12345. However it says 'code error'. How do I fix this?
you could try 1234,0000,****
or
Here is some great source to solve any kinds of Cellular Phones problem.
» Nokia Solution
» Motorola Solution
» Sony Ericssion Solution
» LG Solution
» Samsung Somution
Here is some another Great source to UNLOCK any kinds of Cellular Phones.
» Nokia Unlock Code
» Motorola Unlock Code
» Sony Ericssion Unlock Code
» LG Unlock Code
» Samsung Unlock Code
or If you enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and
get the puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted.
Nov 08, 2009 | Cell Phones
PHONE LOCK FORGET LOCK CODE
» Nokia Solution
» Motorola Solution
» LG Solution
» Samsung Somution
» Nokia Unlock Code
» LG Unlock Code
» Samsung Unlock Code.
Or you could try this :if all else fails.
then:enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and get the
Nov 08, 2009 | Samsung Eternity Cell Phone
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Coffee Makers & Espresso Machines Logo
187 people viewed this question
Top WMF Coffee Makers & Espresso Machines Experts
David Burbee
David Burbee
Frank Russell
Frank Russell
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a WMF Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
