Question about Proform 7.0 Crosstrainer Treadmill
Incline motor on my 380x proform leaks oil how can i fix it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
You will need to replace it
Posted on Jan 04, 2014
SOURCE: incline does not work
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Posted on Apr 18, 2010
Testimonial: "Great thanks"
  • 218 Answers
SOURCE: Proform CR610: electronics work (display
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Posted on Aug 10, 2010
  • 218 Answers
SOURCE: my proform 360p treadmill is stuck on full incline
try thisSometimes incline motors will get frozen in position and need broke free. Try this:
take the motor cover off and take the screw out of the bottom of the incline motor that is attached to the screw assembly. Once you remove the screw you should be able to break the incline motor free. run the incline up and down with the screw still off( laying the treadmill on its side may make this easier). Once it goes up and down (hold the screw so it goes in and out) reattach it then run the calibration described below. If it was just stuck it should work fine.
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
If these instructions do not work to fix the incline motor
check your main harness running down the right leg for breaks in the wires or a loose connection if nothings found you can switch the red and black wires on the incline motor terminal block and see if it goes down. If it does you know you are only getting voltage to one side of the motor. There is a schematic under the motor hood that tells you what the voltage should be when you press the up or down keys. Use a multi-meter to see if you are getting the correct voltage coming from the console to the motor control board and then from the board to the motor. If no voltage from console-replace console if you have voltage from console but not from board - replace board and finally if you have voltage from console and from board replace motor. You will need to test the voltage both when pressing the up key and the down key.
Posted on Aug 14, 2010
ercupa190
  • 12223 Answers
SOURCE: My Proform 380 treadmill will
ADJUST 1) Reed swithc and optic disk.11_15_2011_9_21_16_am.gifIf after you did these adjustments Not work, replace the sensors.11_15_2011_9_21_36_am.gif
Posted on Nov 15, 2011
ercupa190
  • 12223 Answers
SOURCE: proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
Posted on May 17, 2012
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
Incline stuck
Run the software calibration for fix it.go under the HOOD motor and follow the steps or use the owner manual
God bless you
Jul 26, 2013 | ProForm 775 CT Treadmill
I have a Proform xp 550 the incline won't go up...it was starting to go up then made a noise and it dropped down ... how do i fix it?
RUN the software calibration for diagnose, troubleshooitng, fix it.
2) Lube the gear+shaft from elevation Motor
3) adjust the POT from elevation motor, see diagrams attached.
God bless you
Aug 02, 2012 | Proform XP 580 Trainer Treadmill
I have a proform 650 v threadmil, and the left side of the buttons panel (start button and incline levels) don't work. could someone help me?
1) tight all connector wires and clean
2) tight the ribbon cables from keypads.
3) Run the software calibration for diagnose, and troubleshooting, and fix it.
4) lube the shaft and gear in the elevation motor,
5) adjust the potentiometer for better running see the diagram.
God bless you
Jun 19, 2012 | Proform Exercise & Fitness
Every time I put the key in my Proform 590T, the incline rises for a second, and lowers for a second while displaying 2 hash marks. Then, the home screen comes. All speeds work fine for walking/running,...
how long have you had this treadmill? usually when the hash marks appear it means that the console control board is not recognizing the incline motor. even though it does run a little bit that is just the basic test that the treadmill starts but resets after it does not sense the incline motor. These motors rarely go bad so it is more than likely your motor controller that is causing the issue. I have seen this case many times as i am a fitness repair technician. The motor controller fixes the issue 9 times out of 10
Aug 05, 2010 | Proform 590T Treadmill
Proform xp650e, incline driving continuosly in max incline position with loud clunks/bumps
Your treadmill has what is called a "stair step" incline motor. It is common for them to go bad. You would need to remove the motor hood and activate the incline motor. Check to see if the noise is coming from the motor and if so I would suggest replacement.
Jul 28, 2010 | Proform Exercise & Fitness
Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
May 02, 2010 | Exercise & Fitness
Incline does not work
Mar 19, 2010 | Proform CrossTrainer Treadmill
Proform 740CS runs okay but the incline does not
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
Treadmill has always been on a constant incline
Run the machine through calibration. If this does not work you will have either a bad controller or incline motor is bad.
Mar 29, 2009 | Proform XP Weight Loss 620 Treadmill
Proform 7.0 Crosstrainer Treadmill Logo
125 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
