Question about Toys
Flutterbye fairy charged and spinning rotors, but not enough thrust for lift off anymore. doesn't seem to be able to kick into high gear anymore.
197jacobs
  • 226 Answers
SOURCE: I have a S107G Gyro
battery need to be replace charge life is over
Posted on Aug 12, 2011
SOURCE: brand new, (one-day old) havoc stinger won't lift
Try putting the same brand of batteries in the remote. For example, Energizer.
Posted on Jul 25, 2009
  • 26 Answers
SOURCE: TURNS ON, BUT FAILS TO
check for hairs around the rotor shafte and check for weak battery
James
Posted on Dec 26, 2010
SOURCE: the madhawk 300 heli does not have enough power to
I have no soulution, mine does this as well, I just got it 3 days ago! Shure it's been in a few crashes (Learning to fly it) but it was working fine and now it wont take off!
Posted on Jun 21, 2011
bayyagg
  • 1672 Answers
SOURCE: gyropter not lifting off after full charge
Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out.
Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
Hope that helps!
Posted on Nov 22, 2011
My fairy just spins on the base and I have lost the instructions,please can you help
The defect with this toy is cheap design. What is happening is the weights at the waist are support to spin, and lift the top set wings. This causes it to take off. There is a little plastic piece inside shaped like an 8. One side of the 8 is attached to a small round ball attached to the weights (the round ball snaps into the top loop of the 8) and the other side of the 8 is attached to a plastic ball to the top wings. When off the weights hang down and so do the wings. When it starts the weights spin (lifting up) and they are suppose to lift the wings, since there attached to each other. Since the fairy has some violent crashes, the plastic 8 attachment dislodges off one of the other or both. I found on my daughters fairy both were snapped off and the small plastic 8 was laying in the waist. I reattached them and it worked fine for about 5 minutes and it came off again. Now we have lost the 8 piece and out of luck. To try and fix yourself. You can twist off the legs (just turn counter clockwise while pulling lightly). Once the legs are off lift the head off. A stem is attached with a washer, don't lose the washer. Look inside the waist and you will see the little plastic balls hanging off the side of the weights and wings. To fix just snap the 8 piece over the round balls. Probably won't last long because the plastic is already damaged some what and will come off easier each time it reattached. You will need a very small screwdriver to reach down to snap on or dental tools.
Jan 27, 2014 | Spin Master Flutterbye Flying Fairy Doll...
My flutterbye fairy doesnt fly
Jan 14, 2014 | Spin Master Flutterbye Flying Fairy Doll...
Flutterbye fairy is not flying, the wings are spinning but not strong enough to lift her, she is completely charged
Mine is doing the same thing ! Look to see the upper rotors are flying even with each other mine are not ... One seems to be spinning higher . I'm thinking that's my issue
Sep 22, 2013 | Cars & Trucks
We have lost our instruction manuals for our rc heicopters. is the small tail propellar supposed to spin? we can't get them to liftoff the main propellars seem to be working fine.
Sadly, Bob is incorrect here. In a coaxial helicopter, the main rotors spin in opposite directions, equalizing the centrifugal force and allowing the craft to hover without spinning, fine-tuned by the adjustment of the trim control. The counter-rotating main blades and internal gyroscopes provide a stable hover, while the tail rotor serves only to push the rear of the chopper up or down, providing the forward/backward thrust. If you are not moving the right joystick, you tail rotor should be stationary, or perhaps moving lazily from the wash of the main rotors. Sounds like a charging issue. What type of charger are you using? Also, Li/Po batteries are not meant to be fully discharged. Fully draining a Li/Po too many times, ESPECIALLY when they are new, will ruin them. Luckily the batteries on an 032 are easily replaceable. Available on Amazon and many other online retailers, and replaced in about 1 minute with only a small screwdriver. With a new Li/Po, charge them FULLY with the correct charger, and always stop the flight as soon as you are having to give it full power to maintain altitude. Also CRUCIAL is you MUST MUST MUST let the battery rest and cool for after a flight, wait a good 10 minutes BEFORE you connect the heli to the charger, and another 10 minute cool down after charging before you fly.
Hope this helps
r
Aug 19, 2011 | SYMA Toys industrial Syma S032 Ready to...
My helicopter won't take off, it just spins in circles clockwise until it falls over. It's a 4 channel RC helicopter with gyroscope.
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
Jun 06, 2011 | RC Remote Control Helicopter Ready To Fly
My hawk talon v3 will not lift off the ground and the bottom rotor barely rotates.
The lower rotor has a problem where the gear on the motor shaft slides down and does not engage with the rotor gear. You can reach in through the skeleton with a small screwdriver and push the gear back up to engage. Happens every now and again, usually after a crash.
Jan 04, 2011 | Team International Hawk Talon V3 RC Indoor...
Hawk talon v3 wont get enough power to lift off the ground after being fully charged. another hawk talon v3 rear tail rutter wont spin to go forward. how do I fix these problems in these two...
I too had the lift-off prolem and I fixed it by gently pushed the upper gear all the way up, using a nail through the bottom of the copter and a hole in the lower gear, while pushing the lower rotor down.
Dec 29, 2010 | Team International Hawk Talon V3 RC Indoor...
Toys Logo
333 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
