Question about Home
Air jet tub shoots out black flakes
We have just moved into our new home, it had reno's done 7 years ago. The bathroom has an air jet tub. There are holes all along the bottom sides of the tub.I have ran the tub at least 30 times. I started with Jet tub cleaner, then bleach, and then oxyclean. But the problem will not stop. I have let it soak for a day in oxyclean, but that still did not solve it. We have taken the side panel off and can not see any problems. I am very frustrated and would love to know how to fix this!
    New Friend:
It sounds like there is a build-up of some kind in the lines. Replacing the lines may be your simplest solution. Replacing the entire system would definitely fix the black flakes.
Posted on Dec 27, 2013
SOURCE: Jacuzzi tub works.....sort of.
motor for tub does not run checked electric its ok.. is there a reset button and does there have to be water in the tub?
Posted on May 20, 2009
  • 4 Answers
SOURCE: Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
Posted on Jun 16, 2009
  • 80 Answers
SOURCE: Leaks from jets along outer wall
This is a hard fix, The jets are glued on to the back of the tub with an epoxy type material. the jets should spin on and off from the inside of the tub. You need to determine if it is the hole where the jet is that's leaking or if it is the jet assembly and tubing that is leaking. If it is the jet hole that is leaking, spin the jet off and use aquarium grade silicone (Lowes carries it)
spread this around the piece sticking thru the tub and spin the jet back on. This is a hit or miss fix. No easy fix if it is the tubes or jet assembly, full access necessary for this repair.
Posted on Aug 19, 2009
mrhotandcold
  • 248 Answers
SOURCE: i have a leaking jet in a pearl jet tub. it's an
one of the quick ways to fix leaks at jets is by using Millaput two putty resins mixed and worked round the outside of the defective jet hope this helps
Posted on Oct 03, 2009
  • 100 Answers
SOURCE: I have an aquaglass tub that was installed by our
aquaglass has great customer service 731-632-0911
Posted on Feb 15, 2010
What is the best and safest way to remove the bacteria flakes from a Kohler Purist BubbleMassage Air jet tub?
http://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1198327_2.pdf
Call 1-800-4KOHLER 1-800-456-4537)
some parts are under warranty,call them b4 you do anything,they will help figure it out,the link is your manual
May 31, 2015 | Kohler K-1110-G-96 Purist BubbleMassage...
Brown water comes from tub faucet
it may not be your grohe valve it could be your hot water heater check a o smiths web site about rust color water its actually a bacteria
Feb 23, 2013 | Grohe Home
Black flakes coming out
Likely the liner of the duct. Possibly a poor seem that is peeling up, possibly a rodent has gotten inside and chewed up some of the pieces. Either way, yes, more money. Possibly needs a duct cleaning, maybe some new duct, tough one. Best Wishes!!
Sep 19, 2017 | Mitsubishi Mr. Slim MXZ30TN Air...
Please help me I have a American Standard whirlpool tub. I have flakes coming outta the tub when the water level reaches the jets.I have bleached the tub turned the jets on, drained the tub and did the...
Are they white flakes? Sounds like you have lime deposits turning loose in the plumbing.
Was the unit purchased and installed new? Maybe the privious owner had a hard water problem.
In either case, you may have to invest in a water softener.
HTH,
Mike...
Dec 07, 2009 | Water Heaters
Can not get the jets to work
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Dec 02, 2009 | Home
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Jun 04, 2009 | American Standard 2770.018w.020 Cadet...
Home Logo
138 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
