Question about 2001 Pontiac Sunfire 2DR Duraflex Millenium Wide Body Rear Bumper - 1 Piece
Error light on at odometer
Battery cable was loose. fixed it then when started up error light came on
    Champion:
  • 239 Answers
HAVE CODE PULLED,OR DRIVE IF LOW VOLTAGE CODE
AND IS CORRECTED W/ TIGHTEN CABLE LIGHT SHOULD
GO OUT IN A FEW DAYS OF NORMAL DRIVING
Posted on Dec 27, 2013
My 2005 dodge neon's battery won't hold a charge, lights flicker and dim and on the dashboard the word fuse flashes, what is going on?
Could be a bad battery but I suspect your battery cable is either loose or corroded or dirty. Before you pull the battery disconnect your battery cables and clean them both ends and when you put them back on make sure you have good connections and tighten good.If that does not work pull your battery and get it tested at a battery out let . they should do that for free.
Jan 10, 2016 | 2005 Dodge Neon
Why does it turn over but frequently won't start?
Hi, Mike and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2005+kawasaki+vulcan+1600
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 01, 2015 | 2005 kawasaki Vulcan 1600 Mean Streak
Error light on
The ECU , detected and recorded the battery cable fault and put the light on, it will need to be put on a scanner to reset the light
Dec 22, 2013 | 2001 Pontiac Sunfire 2DR Duraflex...
My 97 Chevy Malibu's odometer and trip read "error". How to fix?
You'll need to reset the Electronics Control Computer otherwise called the PCM/ECC/ or ECM. You can do this by unhooking the battery cable for about 15 minutes. If this does not reset it, you may have to do it for up to a day then try hooking the cables up again. See if this works.
Aug 27, 2012 | Chevrolet Silverado 1500HD Cars & Trucks
My 2004 Blast was running perfect. Went to start it and nothing. There'sno electric getting through. Had same symptoms when battery cable was loose on the terminal. I turn the key and the neutral light...
Check the battery terminals to see if they are clean and tight - if they are - check the fuses. if they are good - wiggle the key around in the switch, those switches are notorious for getting sloppy.
Jun 27, 2010 | 2002 Buell Blast
Have a 2002 Ford F150. Service engine light soon is on. Is there a way to manually pull the codes?
On my 02 ford pu, if you have the digital odometer, I hold the odometer/reset button down while starting engine, it goes thru test and gives error codes. Disconnecting negative battery cable for a minute, then reconnecting, will turn off the light if there are no issues.
Mar 05, 2010 | 2002 Ford F150 Regular Cab
Odometer MALFUNTION - camry 2002
youre going to need to replace the speedometer unit.
Dec 28, 2009 | 2002 Toyota Camry
Speedometer needle is stuck behind the pin
Here is how it happens, The positive battery cable was loose, after adjusting the battery cable the speedometer needle went under the retention ping.
How to fix it:
1- remove the positive battery cable
2- have a person to look at the speedometer needle
3- Make the battery cable to touch the positive terminal of the battery (this will make the needle to jump over the retention pin)
4- Tight cable again.
Aug 11, 2009 | 2001 Buick Regal
Car isn't starting
I was have this problem. Battery is low. Charge battery or use cable to start. You can check the problem using Diagnostic Trouble Code. Cycle ignition key On - Off - On - Off - On within 5 sec. The odometer will show teh P-code for the DCT code number. Error code for low battery is P0562. Only "DONE" displayed on odometer inicates that no DTCs are present (no error) and the procedure is completed. PCM memory has been cleared within the last 50 ignition cycles. Hello from Croatia.
Apr 29, 2009 | 1999 Chrysler 300M
2008 Toyota Tacoma Remove maintenance light from dashboard
you can reset your cars computer by taking the positive battery cable off the battery and waiting 2-3 min and then touching the positive cable from the car to the negative cable which is still attached to the neg post on the battery for about 5 sec and the hooking it back up. that will reset the computer. if the code that was given is a koer code and you havent fix the problem the code will most likely come back but this is a good place to start and at least the code will be gone for awhile.
Mar 30, 2009 | 2008 Toyota Tacoma
2001 Pontiac Sunfire 2DR Duraflex Millenium Wide Body Rear Bumper - 1 Piece Logo
70 people viewed this question
Top Dur-a-flex Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Dur-a-flex Vehicle Part and Accessory Expert? Answer questions, earn points and help others
