Question about Konica Minolta magicolor 2300DL Laser Printer
Upgraded to Vista; can't change toner; no status monitor
I cannot retrieve my status monitor to change my toner on my magicolor 2300w since I've upgraded to windows vista home. I can't print because my toner needs to be changed...please help!
    President:
  • 688 Answers
Apparently your driver isn't compatible or iwas corrupted by the install of vista.
Here is a link to download a clean driver try installing it and see if your printer works.
http://partner-printer.konicaminoltaeurope.com/vista/table.htm
Good Luck and If this helps please leave a vote in FixYa Thanks
Posted on May 18, 2009
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Driver
Here is the link to download your driver.
Konica Minolta Magicolor 2300W
Thanks
Mar 12, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Replaced Black TOner but still says it is empty
One way you could reset the toner is using the service mode.
Is this printer a 2300w ? If so, open the front door of the printer, turn on and hold down the cancel button for at least 20 seconds, that resets all the counters to factory defaults. The only problem is, that it will set all the toners to 100% and standard capacity, but you can change that in the software. One good thing is, it sets the OPC drum,
Fuser unit, transfer belt, everything to 100%
Delboy
Jan 26, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Minolta 2300w windows vista
try changing a usb cable vista should find some new hardware
Jun 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2300w
color light has nothing to do with this, first try once more to reinstall drivers, if still shows wrong printer, then you have to upgrade firmware, because if you installed the correct mc2300w drivers and status monitor tell you wrong printer there can be 2 things. firmware is broken or printer/computer usb port is broken. so if you can use another usb port or another computer try it or LPT cable. and as a laast thing update firmware.
May 17, 2008 | Minolta magicolor 2300W Laser Printer
Cant get the toner replace promt to hightlight so I can replace it. Tried restarting
install status monitor to computer and from there you can choose change toner X and printer turns the cartridges in right place. or if you cant change that way, then under the front cover there is a switch, look the knobs on front cover and find it, it should be upper left corner, then you can rotate the cartridge manually.
Mar 14, 2008 | Minolta magicolor 2300W Laser Printer
Problems with the changing the toners
Pleas try to install the status monitor again, if status monitor is installed correctly, then the toner replace should be available
Feb 12, 2008 | Minolta magicolor 2300W Laser Printer
PRINTER COLOR
there should be some quality settings in driver menu or status monitor, check these.
Feb 06, 2008 | Minolta magicolor 2300W Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
192 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
