Question about Kenwood Car Audio & Video
It is in protect mode, how do i reset the system
Remove the radio faceplate. Use a paperclip or any other narrow object to fin inside the RESET button under the faceplate
Kenny T.
Posted on Jun 02, 2014
  • 26 Answers
U may try to disconnect your battery cable to reset it,, and see if that could possibly fix your problem....
Posted on Jan 30, 2014
How can I get Dynex TV out of "protection mode"?
the protected mode kicks in when there is a safety issue with the receiver. This usually comes from an overload to the system via a short in the system or perhaps a surge in power. Your receiver shuts down, and you'll need to shut the entire system down to fix it.
In some older homes, some of the wiring doesn't deliver the "cleanest" power, delivering minor power surges to the items you plug directly into the wall. If your receiver is plugged directly into the wall, purchase a surge protector to stop this
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYa9W0Mi
God bless you
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYZm8THG
Jul 20, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
SHARP BA200 Protect Mode?
Check the speaker wires for shorts, if okay! the audio output ic's are loading the circuits causing the protect mode to engauge, only option replacement of the above mentioned parts.
Apr 21, 2012 | Sharp CD-BA200 CD Shelf System
Have a SONY DAV DZ370 Home theater system. Displays 'Push Power Protect'. Tried 'cold reset' and all the manual stuff to no avail. Should I reset the M16C micro-controller or is there...
Push power protect is an indication of an output failure ( Amplifier ). The Home theater system is asking you to switch off the power to prevent further damage. This mode is called protection mode and you will need professional help sort it out.
Aug 11, 2011 | Audio Players & Recorders
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
Mar 24, 2011 | Sony MHC-GS100 CD Shelf System
How do you reset system... it will not turn on says protection .. everything is unplugged and still does it..
Resetting won't solve your problem. The display is telling you there has been some internal damage ( most probably output stage ) and needs fixing.The system goes into protection mode to prevent further damage.
Mar 15, 2011 | Toshiba Audio Players & Recorders
Error F61 How to reset SC-HT995W system?
I'm sorry to say, but an F61 error can not be cleared by a reset. Please see the link below for an explanation of protect mode (F61 is Panasonic's version of protect). Usually the output amp pac will need to be replaced. This will cost between $75 and $100 for the part. Feel free to post any additional questions here.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Oct 19, 2010 | Panasonic SC-HT995W System
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
Sony str-d715 flasses protector
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 03, 2009 | Sony STR-D700SS Shelf System
PROTECT mode
I have a Sharp cd-c2900 home stereo and a "protect" word came up on the lcd?? The stereo is not working now and olnly shows a "protect" word?? Can you please tell me if there is a reset button some where?? Thanks , "Joel" My Email address>> Jovelopa22002@yahoo.com
Jul 17, 2008 | Sharp CD-C2900 Shelf System
Car Audio & Video Logo
211 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
