Question about Cell Phones
Fix po 1388 code dodge ram
Well not start
  • 1596 Answers
SOURCE: 2003 dodge ram code po 700
The Manual Shift "WORKING" is a Good Sign , In Older Models this would Point to Vacuum Modulator Let Me Do Some Diggin and Maybe Come Up with A Sureshot Hit on EXACTLY what it is Im sure its Relased to A Electronic Modulation od TCM
Posted on Jan 29, 2009
wracefans24
  • 1985 Answers
SOURCE: won't start engine code 1388
Auto shutdown relay control circuit=p1388
Posted on Nov 24, 2009
kirkx
  • 2019 Answers
SOURCE: I have a 2008
P0489-egr Control Circuit Low
P042E - EGR Control Stuck Open
So when the engine is cold, feel the EGR valve.
They start it up.
At idle it should stay cold.
It is heats up quickly, then the EGR is open at idle, and it should not be.
It is probably manually binding from exhaust deposits.
It can be cleaned with a wire brush or chemicals.
If that does not work, you can just block it off.
EGR is not good for any engine, because it causes deposits on the back of the valves. But it is necessary on some high compression engines, in order to poison the mixture enough to prevent predetonation. But a diesel can never have predetonation, so the EGR is totally negative and should be removed for optimal life span.
Posted on Sep 12, 2010
  • 9 Answers
SOURCE: what is the PO 441 code on a 2004 dodge ram 1500
P0441 is a "purge flow error" which can be a result of a small leak or some other problem with the hoses to the canister. Here is a good reference site for more info: http://motorage.search-autoparts.com/motorage/data/articlestandard/motorage/102005/149558/article.pdf
Posted on Dec 29, 2010
  • 176 Answers
SOURCE: What is the fault codes 1388 and 1389 for a 2002
No voltage sensed at the PCM (powertrain control module) when the ASD (auto shut down) relay is energized. It could be the ASD relay, the PCM, possibly their relays.
If you are interested in further diagnosing the problem, I will be happy to assist you.
Posted on Mar 28, 2011
ENG. LIGHT ON CODES PO 442 ANDPO 445 IS SHOWING UP ON SCANER
The PO 442 code is an EVAP system small leak, either in the evaporative system or cooling. Sometimes this will occur after a drenching rain and remain until the diagnosis code is reset, usually will disappear after you read the codes. If not, a dealer can reset the code system via the radio believe it or not. PO 445 is similar, an EVAP system code but is usually related to gas vapors being sent to the engine rather than through the atmospheric venting system. Check the gas cap system here first, a gas cap not properly tightened (3 click) will sometimes cause this. Also, look to the spark system wiring harness or purge control solenoid.
Sep 16, 2014 | 2001 Dodge Ram 1500 Truck 2WD
Code po 522,on my dodge 2004 caravan how do I fix it.
well it means that you have low voltage to your oil pressure sending unit, try to add oil, only after checking to see if there is the correct amount, has the oil light come on?
Aug 13, 2013 | 2005 Dodge Ram 1500
Why is the code of po 106 coming up i have a dodge stratus 1997
Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem fix this then you can remove the code
Jan 12, 2013 | 1997 Dodge Stratus
Car codes Dodge Caravan 2002
new spark plugs basic tune up this will fix it ,then fine the small vacuum leak fix it this should take care of it.
May 10, 2010 | 2002 Dodge Grand Caravan
Won't start engine code 1388
Nov 14, 2009 | 2002 Dodge Neon
What is the most common cause of an error code: 0040 and 0041 in a 2003 dodge ram 1500?
no such codes, it would be something like a po 441 or po 045. recheck your codes,good luck.
Oct 28, 2009 | 2004 Dodge Ram 1500
My 2004 Dodge Ram engine light came on,put in drive it wouldn't move. I had computor check done & showed code PO 700
the code indicates a malfunction in the transmission control system. I will be back with you to see if I can find the location of this box, if you don't already know.
Jul 01, 2009 | 2004 Dodge Ram 1500
Fault codes
The P1684 code simply means that the battery has been disconneted within the last 50 starts.
Jun 11, 2009 | 1996 Dodge Caravan
2005dodge ram 1500 Hemi missing when taking off
404 & 406 appear EGR related. Check all hoses & connections at EGR. My guess is once EGR is fixed 430 will disappear. I believe EGR is just below & to left of alternator, 2 small bolts holding on.
Feb 16, 2009 | 2005 Dodge Ram 1500
Po 108 fault code
Sounds more like a mass air flow sensor problem.
Jan 09, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
