Question about GE Profile PDW8600J Built-in Dishwasher
Dishwasher runs thru cycle, but no water
The washer sounded different, when I checked it the inside was hot but there was no water in it. I tried to reset it and powered it off for a while but it still won"t fill with water. I also checked the water shutoff connected to the washer and made sure it was open
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Change the water valve solenoid Vitally
Posted on May 18, 2009
Dishwasher runs too long
Good Morning Tessa,
I understand that your Frigidaire dishwasher, model# FDB700BFC, is running too long. I also see that it seems to be getting stuck on one particular cycle and runs continuously for hours even though the water is hot. It sounds like there is possibly a miscommunication between the different boards inside your appliance. I please ask that you try resetting your dishwasher, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
Have bosch SHE45 EVOLUTION PUSH BUTTON ON RIGHT FRONT PANEL. MY WASHER WILL NOT RINSE ALL THE SUDS OFF THE DISHES OR DOWN THE DRAIN AND HAD BAD SOAP RESIDUE BUILD UP. i HAVE USED LEMISHINE ONE TIME AND...
I started running the Hot water faucet till I got really Hot water then I started the dishwasher with No dishes in it and let it fill with hot water till it was almost full then I added a half a gallon of white vineagar to the water and let the dishwasher go through its cycle. It cleaned up the inside of my dishwasher then I put the dishes that didn't get clean and that had a soap film on and rewashed them with plain hot water and poured the other half a gallon of vineagar in the dishwasher and let them wash the complete cycle. It cleaned the dishes very well. I don't know if you will have the same results but it worked for me..... Hope this helps, your welcome to give it a try vineagar is pretty cheap... and it won't hurt anything inside the dishwasher or dishes.
Feb 12, 2011 | Dishwashers
The soap holder is opening during the wash cycle but the soap tablet is not dissolving. Any ideas?
Is the water coming on? Is water hot enough? Is washer overloaded, water jets aren't hitting the soap? Maybe try a different brand of soap tablet? Run the dishwasher in "heavy soil" mode which will use hotter water and run for longer?
Nov 20, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
No water coming into washer
Behind the dishwasher there is normally a two little taps 1 for cold water and 1 for hot water, check that the taps are turned the right way and are letting the water into the mechine. post back what you find.
Apr 05, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher motor sounds like its struggeling to run. oR LIKE it's bogging down during washing cycles any and all cycles. there is water going into the washer but when washing it sounds like there is no...
Try pouring water from the front. The pump has got air traps inside. This will ease your problem.
Also check whether the spray arm turns freely without any obstacles.
Mar 30, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Sep 08, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
Water fills up dishwasher after complete maybe a day or two later
Sound like the hot water sonenoid is stuck in the open position. Locate this solenoid and tap it lightly with a small hammer while the hot water is open. If it does not stop it will beneficial to have this part replaced. I hope this will help.
Jan 17, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dish washer
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is
cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher.
Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature
of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than
120 degrees Fahrenheit.
May 14, 2008 | EuroTech EWF150 Front Load Washer
GE Profile PDW8600J Built-in Dishwasher Logo
195 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
