Sharp 7.8 es-7815TS
Bearing was so annoying
Where can I find electronic board for this sharp es-s1251 This unit electronic board is already malfunction and I want to fix it.
The circuit board will have a part number stamped on it, f sharp can't help , google it ,you may be able to find one online.
Jan 03, 2018 | Sharp Televison & Video
Mi televicion es sharp no tengo micodigo el modelo de mi control es rcu403n
¡Hola
C?digo de configuraci?n para TV Sharp con mando a distancia RCA 403 mando a distancia es
[0093]. Aceptar.
Aug 12, 2011 | RCA Televison & Video
SHARP ZQ-6300 MULTILINGUAL ELECTRONIC ORGANIZER128KB JE NE TROUVE PLUS MON MOT DE PASSE INITIAL POUR POUVOIR RENTRER DANS LES PROGRAMMES. COMMENT FAIRE POUR REINITIALISER MON AGENDA ?
Mon français n'est pas très bonne. Si vous avez oublié votre mot de passe il n'y a rien que vous pouvez faire pour récupérer les données protégées. Vous devez supprimer toutes les données protégées.
2nd->Function->3->Secret Data->Y
Cela effacera toutes les données secrètes.
Aug 02, 2010 | Sharp Personal Organizer & Spanish/English...
Sharp ar -m351 Error codes L4-30
sharp printer mx-m450n error code l4-02
Nov 24, 2009 | Sharp AR-M450N Copier
I put new wheel bearing on my 1997 lexus es 300 now my traction light and abs light will not go off and when i apply my brakes the pedal reaches a point and release
are you sure you got the assembly for ABS. There should be a ring that can be see. Also check the connector you may of unplugged. Its real easy to install the wrong bearing if you did'nt know.
Nov 08, 2009 | 1997 Lexus ES 300
Camcorder gone bad
First a few questions:
1) Will the unit accept a tape or is it completely dead?
2) In camera mode, does the viewfinder work?
Thanks,
Dan
Feb 17, 2009 | Sharp VL-A45 8mm Analog Camcorder
Does the TOSHIBA TA8445K Vertical Deflection IC fails when the Deflection Yoke is Dirty?
hola tengo un tv onwua que no me habre el verticar ya revise los voltajes y estan bien pero en la pata 11 tengo solo 7 voltios en ves de 12 voltios cual puede ser el problema de mi parte muchas gracias.mi email es ruben_148_2@hotmail.com.
Mar 05, 2008 | Sharp Televison & Video
Sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Feb 15, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Washing Machines Logo
Top Washing Machines Experts
