Question about Dryers
Dryer does don't heat when u turn it on - Dryers
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 32 Answers
If it is electric, the heat unit is probably burned out. If it is gas, the igniter (heat coil) which lights the pilot may be burned out. Neither is a major problem, although some repairmen may tell you that it is.
Posted on Dec 27, 2013
Neptune dryer has power but will not spin.I hear a faint click comming from the left side. model#MDE9700AYM
An electric Neptune clothes dryer, like most electric clothes dryers, has two circuit breakers: one for the drum and another for the heating element. Both breakers need to be in the "on" position for it to run properly. Go to your main circuit box. Reset both of the dryer's circuit breakers to the "on" position. If one of the breakers trips again, there's a problem with the dryer component that it operates. Contact a dryer repair technician to evaluate the machine's condition.
The lid switch is a small latch located on the interior of the door frame on your Neptune clothes dryer. It keeps the door securely shut when the dryer's on to prevent injury should you open the door and reach inside while it's turning. If the lid switch becomes damaged, the dryer won't turn on even though its lights might work. Run your finger over the lid switch and listen for a clicking sound. If you don't hear a sound when the latch is compressed, it's faulty and needs to be swapped out.
The thermal cut-off is a heat-sensitive safety feature on a Neptune clothes dryer that shuts off the heating element if the dryer overheats. After it activates, it can't be reset; you must replace it. Until it's replaced, your dryer might only partially function, so while its lights might turn on, the dryer might not spin or heat. Don't exchange an old thermal cut-off for a new one until you first determine what promoted it to trip, otherwise your dryer likely will overheat again.
Oct 19, 2012 | Dryers
The dryer heats but the drum does not turn. The belt is fine, could this be the blower? model # sdg3606aww
If the unit is heating...I don't think it is the blower. It may actually be the motor-part: 2200376
Sep 07, 2011 | Maytag SDG3606A Gas Dryer
Whirlpool supreme lhi 5801 won't heat. The coil turns red but won't ignite anything. I'm pretty sure the gas is on. I don't know what else it could be...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 03, 2011 | Dryers
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a gas dryer, when I turn it on the gas kicks on but when it cycles off it doesn't kick back on and the clothes don't dry
heatman101
Jun 30, 2011 | Maytag Dryers
Dryer gives heat but don't run you don't hear the motor running
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 23, 2011 | Dryers
Mde3706ayw Dryer will run for about 10 minutes and then turn off. I have to wait about 30 minutes. I have tested or replaced the thermal fuses. The dryer will run continuously when set on no heat so I...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer runs but don' heat up. It's about 15
If you have a gas dryer then here is a tip that I wrote about that problem...
If you have an electric dryer, check out thet tip for electric dryers at the bottom of the gas dryer tip...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 29, 2010 | Whirlpool Dryers
My dryer
motor over heating, i would check to see that you don ont have a venting problem, inside the dryer if you have a large amount of lint build up it can cause the motor to over heat
Apr 11, 2008 | Dryers
Will not heat up
Did you check for 220 volts to dryer? Power to the dryer is made up of 2 110 volt circuits. If 1 is down it can still run but not heat. Check with voltmeter across 2 outside prongs of plug with it pulled partialy out of socket. BE VERY CAREFUL.
Nov 05, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
Top Dryers Experts
