Question about Element Electronics FLX3210 32 in. LCD TV
LED on but doesn't power up - Element Electronics FLX3210 32 in. LCD TV
  • ppow
    ppow Dec 28, 2013
    whenever the power goes out or the TV is unplugged for a short time, the TV won't turn back on. The LED is lit but nothing else happens
  • charles Dec 30, 2013
    prob a psu fault perhaps bad capacitors
Dosn,t work
If powered up and no Video, the video circuit was damaged, or compromised. It needs a professional service agent to fix the unit.
Jul 29, 2014 | Sony BRAVIA KDL-40EX620 40" LED TV...
My laptop struck by the lightning. The power LED doesn't turn on, but the wi-fi LED turns on without power on, CPU fan starts as soon as i turn on the charger. But turning on power button has no...
Try to check if battery is removable. Remove all power source (battery and charger). Press power button for 10-20 seconds. Plug in with charger. Power on.
Sep 14, 2013 | Computers & Internet
My Emerson 9X Power flashlight doesn't work
short circuit causes this problem, no hope better replace it by expert.
Oct 22, 2012 | Emerson Led 9x Led Flashlight 4-pack...
Why doesn't my magnavox led tv turn on?
if just an stand by indicator at the front panel check for bulging capacitors at the power supply board.
Sep 30, 2012 | Funai Magnavox 19" Class 720p 60hz LED TV...
Printer doesn't accept the paper,power led only glow
It's onboard failure message(eeprom, rom, or microprocessor), just replace your mainboard and calibrate the machine. It solve the problem, perhaps.
Jan 19, 2012 | Epson Passbook PLQ-20 Matrix Printer
When i putu the power cable on, the led light blink once and goes off. the screen is black. no fan is moving or any sound.
You should try to start your computer without the battery installed. If that doesn't work, you should try another power supply. If that doesn't either do the trick, it could be the motherboard causing the trouble.
Jun 14, 2011 | HP 530 Notebook PC
My hp 2133 powers on but the power led doesn't light up I don't have any indicator as the power led blinks whenever I put my laptop to suspend.
can you just please completely remove your laptop battery --- keep it away for couple of minuets then put back run the pc i hope the problem is gone
May 24, 2011 | HP 2133-1 Mini-Note PC
Ga-8sr533 hdd led not working
May be , you didn't connect the connector of ur LED on motherboard.
or it's not connected properly.Please refer motherboard manual for the same.
Thanks,
Mukund
May 15, 2009 | Gigabyte GA-8SR533 Motherboard
Ps3 nodisplay, although I reset output video
minhpham have to tried to insert any disc like moves, song differnt game frm call duty.
and if it dosnt work let me knw.
abdz
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
Element Electronics FLX3210 32 in. LCD TV Logo
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
