Question about Wharfedale Audio Players & Recorders
Is there a way to wall mount the Wharfedale Modus Cube and Supercube speakers?
I have a nice set of Wharfedale Modus Supercubes (from the late 90's I believe). They are the ones that have the tweeter mounted separately on top of the cube. We remodeled and I would now be better off if I could somehow wall mount them. There are no keyholes or threaded slots for a universal bracket to work with.
4 Suggested Answers
SOURCE: Wharfedale Modus One
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Posted on Mar 11, 2008
SOURCE: detached cube speaker
I had the same problem.
Step one: pop of the grille with a screwdriver or knife inserted from the bottom so that any marks will be hidden when you get the two halves back together.
Step two: If the speaker is held in by screws, you are lucky. Just unscrew the speaker and remove it. If the speaker isn't held into the case by screws, it is a newer model that is glued to the back cover / box. You can separate the glue with a bread knife or thin screwdriver (I used a paint scraper and thin screwdriver). Be careful to work around all four sides. Also, there is a small (about 1/4" long) plastic bump in the center of each of the four sides that clips into a matching groove in the speaker, so you will have to spring apart at least two adjacent sides at the same time to release the speaker from the cover easily.
Step 3: Once you have the speaker out, remove the acoustic sponge, and sit the bottom half on a solid table. Make sure the rubber gasket between the speakers is seated properly and note the position of the 3 notches in the hole of the bottom speaker cover. Place the top speaker cover in place and insert the white plastic 3 pronged clip though the the hole so that the prongs match the notches. Press down hard with two thumbs and it should snap into place.
Step 4: Replace the sponge and push the top speaker back into the cover. Replace the screws if you had them. Otherwise you can glue it again but the clips are quite solid if not damaged by the removal so you can save some effort the next time it happens by leaving it unglued, and just snapping the speaker into place.
Step 5: push the grille back on.
Posted on Dec 28, 2009
SOURCE: Tweeters only works when touched!
This is not a solution, but I have the same problem. Obviously, the problem is with the tweeter not the crossover. I can't find a replacement tweeter so i am about to take it to my local stereo repair store and see if they can fix it. If you find a replacement tweeter, let me know.
Posted on Sep 29, 2010
Adjust treble
is it too much treble and you want to attenuate?
if thats the case i have a simple suggestion. wire used for doorbells has no place between an amplifier and a speakers. you could try obeying for a set of modus cube speakers. they're great and cheap. between 10 and 25 GBP a pair. you may even be able to find the centre speaker. if not just get 6 speakers or 3 pairs. use 5 of the 6 and keep a spare. wharfdale modus cube main speakers
or Wharfedale Modus Cube Main Stereo Speakers
theres 2 sets easy to find.
Apr 11, 2014 | Sony DAV-C700 System
Vibration through speakers on my jvc home cinema system
try tightening the screws on the cabinets or buy a full set of
Wharfedale Modus Cube Main Stereo Speakers to replace the bad ones
Mar 23, 2014 | JVC Audio Players & Recorders
Wharfedale Modus one six - one woofer cone is cracked. It still plays, but needs to be replaced. Where can I buy a replacement, or is it possible to repair the cone?
Yes, you can bring it to electronic repair shop to rewind the coil. or buy it in the electronic shop. if they don't have same brand you can replaced it with other brand same size and same watts of speakers. thanks
Apr 30, 2011 | Wharfedale Modus One-Six Speaker
I just brought some wharfedale one-three speakers and have them hooked up as the rear speakers. Can i get the sub to play still and do i hook the speaker wires in the top or bottom?
Do you mean "Modus 13"?
See picture 6...
http://www.freeads.co.uk/uk/av/audio/hi-fi/speakers/8402337/wharfedale-modus-one-three-speakers-black-rare-bi-wire-quality/view
Put the jumpers back in as shown. Hook your speaker leads to either top or bottom. The entire array of drivers will be active.
Make your receiver aware they are LARGE for the purposes of bass reproduction so some bass will get out to them. FYI, many AVR's will only allow Large Rear speaker selection if you also have Large Fronts. Refer to the manual(s).
Mar 07, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
I need to buy one Wharfdale Modus 8 speaker only.
Hi.
I have this modus 8 in good condition want to sell it if you wish.,
my email: devizal@cbn.net.id.
locatd at jakarta,indonesia
my mobile nos. (62) 816-809066
cheers
Apr 18, 2009 | Wharfedale Modus One-Six Speaker
Modus one six speaker not working properly
Hi. If you have an digital multimeter to hand you could always drop the drive unit (the metalwork with the paper cone) out from the enclosure and make sure the resistance of the voice coil is between 4-16 ohms. If there is no reading then the voice coil could be open circuit and the whole drive unit will need to be replaced. If the others rattle check the mounting screws are not slackened off. Especially if you have been driving them hard!
Dec 23, 2008 | Wharfedale Modus One-Six Speaker
Modus One Six spare parts
You may want to check ebay, they sometimes have drivers for sale. Additionally, I would contact IAG (International Audio Group). They are the distributor for Wharfedale here in the states and may be able to help you. I also have the modus one-sixes, modus-two's, and modus center and was albe to get replacement parts from IAG, never needed a driver though. How did you blow it anyhow, these speakers can take a beating, are you using a quality amp? Underpowering the speakers and trying to drive them loudly = demise for your speakers.
May 03, 2008 | Wharfedale Modus One-Six Speaker
for pictures.
good luck Danny Mol
the netherlands
Jan 15, 2008 | Wharfedale Modus One-Six Speaker
142 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
