Question about Pioneer XVDV830/SDV830 DVD AUDIO HTP System
Touch sensitive button not working on XV-DV77 DVD Player
I have a pioneer xvdv77 DVD player. The touch sensitive button that opens and closes the tray does not always work. The switch has two copper contacts that touch two contacts on a circuitboard that have what seems like grease on them. Does it use some kind of conductive grease to work? It has another switch for play/pause that is the same type as this one (touch sensitive) and it looks like it has the same type of conductive grease on it, but it has no problems. I only have to barely touch this switch to make it work.
5 Suggested Answers
SOURCE: i a have the xv-dv77 and the buttons on the sytem
Hi, I have the same system and had the same problem with the drive door refusing to open when you press the open button. I fixed it quite easily, unplug every thing, on the rear of the unit, remove the two screws holding the top rear cover on. This will reveal two plastic securing clips for the front top cover, release these and the top cover will slide off easily. You will find that there are two bent over hook wires, where the button is and if you look at the under side of the top cover, you will see two metal contact strips that are suppose to touch these wires. All i did was bend the wires out a little so that they made better contact with the sensor strips. Put it all back together again and hey, it worked right away. Good luck, Richard
Posted on Nov 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: Hi, I have a
I'd advise eliminating any intervening hardware until you resolve the problem.
What exactly isn't working that also goes through a VCR to a TV? How is it all connected, specifically?
"Different buttons". Can you be more specific? Perhaps you just have a remote control issue.
See this link:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
"Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 30, 2011
  • 8457 Answers
SOURCE: The remote control AXD7305 for
Try website like Remotes.com to buy the original remote or very close to it.
Posted on Feb 18, 2011
krb55
  • 604 Answers
SOURCE: Can Pioneer Home Theatre
if the television has audio outputs it can, look on the back of the tv for audio outputs, they would be red and white jacks (or red and black) the red is the right channel and the white/or black is the left. If you don't have audio outputs on the tv, look for an earphone jack, you can buy a cable that will plug into it and then into your home theatre system.
Posted on Mar 16, 2011
Testimonial: "thanks, thought we would have to buy a new connecting cable"
Hi! I have an old model Pioneer DVD player, model numbe XV-DV77 that was working fine one moment, and then the next momennt had a yellow light (standby?) where the power button is. Now it won't turn on at...
As with many of these older type DVD players, they get dry joints on there circuit boards, unfortunately mist service centre's will not even repair them as parts and service time is not cost effective! But for the sake of an enail you can contact pioneer and give them the serial number and a definition of the symptoms and they maybe able to help or point you in the right direction.
Jan 18, 2015 | Pioneer Audio Players & Recorders
How can I programe my DVD Player xv-s332 so that it plays all zones
Have no dvd or cd in the player
step 1.unplug the dvd player
Plug player back in while holding the Open/Close and play buttons on the player
The word TEST and a number should come up on the player Display
Step 2.Press 9 on the remote until the display on the player says 00A0 0000 it should take 40seconds of pressing 9 to get to 00A0 0000 as I think its the last code in the sequence.
step3.Press Standby/on on the remote or player
Wait 15 seconds
Turn player back on.
Let me know if it works.
(I got this hack from another dvd player the JVC xv-302sl but it should work on the JVC xv-332sl
Len..
Oct 14, 2014 | Televison & Video
I have a pioneer dvd/cd receiver player,,, xv-htd540 and the timer light is on,, and the unit wont turn on..
i don't have a solution , sorry . but i am looking for a user manual for the xv-htd540 . do you have one ?? dennis
Jun 01, 2010 | Pioneer XV-HTD520 Multi-disc DVD Player
The dvd player will not play, will not spin -
the internal motor has gome bad change it
Mar 30, 2010 | Audio Players & Recorders
I a have the xv-dv77 and the buttons on the sytem
Oct 28, 2009 | Pioneer XVDV830/SDV830 DVD AUDIO HTP...
How do I unlock my Pioneer DV-310-s so it will accept all dvds, thanks.
Here is how to Make your Pioneer DV-310 regionfree.
Use this link and go there.
http://www.pioneerfaq.info/index.php?question=Firmwares
Search for file YJA8703A almost in the bottom under DV-310.
Download and burn on CD with nero,make sure the CD is being closed after burning.
The just mount the CD in your DVD player and press play.
#1. Press upgrade.
#2. Wait,don´t touch anything now.
#3. The tray will open after about 5-10 sec,take out CD.
#4. Player will uppgrade under about 1-2 minut,then the tray will close by it self,and the player says "CLEAR".
#5. And now here is the secret. When player says "CLEAR" ,push and HOLD the "enter button on THE PLAYER until it turns off(about 5 sec).
And there you go,standing infront of your brand new Multi regional Pioneer DV-310.
At least this worked great for me.
Good Luck!
/Jiinsen
Aug 08, 2009 | Pioneer DV-310 DVD Player
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
Pioneer xv htd520 won't play dvds
This is a common problem for this model. It has a memory IC that must be replaced. This is a surface mounted IC that requires exceptional soldering skills to replace. I work at an authorized Pioneer service center and have repaired a good number of these for this exact problem. Unless you have great soldering skills it is not something that should be attempted to do yourself, it can cause permanent damage to the board if not done perfectly.
If you have the proper skills and soldering equipment I will be happy to give you the Pioneer part number so you can replace it yourself. If not, then you really should just take it to a service center and have a professional do this.
Let me know if you would like that part number.
Dave
Dec 12, 2008 | Pioneer XV-HTD520 Multi-disc DVD Player
DVD MALFUNCTION [MODEL PIONEER XV-DV131 (DVD/CD HOME THEATER]
I have the same problem with my XV-DV333. Search on inet and this came up: "... Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. What do I do? You need to get a Pioneer Service Remote. When you have it you should press: [ESC] [A.MON] [Numbers], where [Numbers] correspond to the region number you want to set. Be aware that you can only set this once, if you set the wrong region number for your area, there is no turning back. " WTF! Am I supposed to get a service remote to get this thing working again. I haven't done anything and it worked before:/
Sep 08, 2007 | Pioneer XVDV830/SDV830 DVD AUDIO HTP...
118 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
