Question about Microwave Ovens
Got a lemon
I bought a microwave and oven wall unit by Jenn Air I have owed it for 4 years and has had it fixed 4 times. What can I do then continually have this piece of **** fixed over and over again. It was not a cheap purchase.
    Top Expert:
  • Microwave Ovens Master
  • 44,949 Answers
Price paid and brand name are not always reliable measures of quality. You may have to put up with endless frustration until eventually you replace it.
Posted on Dec 27, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
elhomspam
  • 58 Answers
SOURCE: Jenn Air JMC7000ADW
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
Posted on May 01, 2008
SOURCE: Jenn-Air Microwave - no power
Had the same problem. Removed the unit (snapping off the upper and lower trim rings was a chore but they do snap off) and tested the power. Plug behind the unit was good. Pulled the cover and checked the thermal fuse with ohm meter. No good. Replaced fuse, microwave would run for a second, then light goes dim and it buzzes, then it blew the fuse. Per above suspected Capacitor. Changed that, and we are back up and running. Thanks!!
Posted on Sep 27, 2008
SOURCE: JMC7000ADW Blows circuit breaker
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
Posted on Oct 11, 2008
  • 3 Answers
SOURCE: Jenn Air blt in microwave doesn't heat -Otherwise works fine!!
Replace the door switch I ordered mine at www.repairclinic.com
Posted on Feb 06, 2009
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
Sep 29, 2014 | Jenn-Air Microwave Ovens
I am installing a Jenn-Air Wall Oven and Microwave Combination. The problem is electrical. The electrical cable in my wall has 3 wires: a black, a white, and an unshielded ground. The oven/mircrowave...
Do you have the installation instructions that came with the oven? An electric oven requires a 220V circuit and the cable coming out of the wall you described is a 110 V circuit.
Nov 23, 2017 | Jenn-Air Microwave Ovens
Jenn Air Built In Microwave JMC8127DDS - no power to the unit. I've removed all the screws I can see, but can't get the microwave to slide out to see if it is plugged in.
Be advised that they are heavy. You may need 2 people to check this. The bracket may have a lip on the wall section that you have to take the weight off of to move it.
Dec 16, 2017 | Jenn-Air JMC8127DD Microwave Oven
HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
Dec 19, 2008 | Jenn-Air JMC7000 Microwave Oven
No power on Jenn-Air JMC 7000 ADB Microwave
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Dec 18, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-air microwave JMC 7000 ADB has no power
Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
