Question about Concord Fans RM-100 Remote Control
How do I get instructions for the concord RM-100?
It only goes on when I push the delay off button. It does not go on when I push light on/ off button. What is the delay button for? Need instructions. It was already in the home when I moved in.
Need code for concord ceiling fan remote RM-100-A
There is no code! You have to match the frequencies in the transmitter & receiver. The dip switches in the transmitter will be where you put the battery.
Sep 02, 2014 | Dryers
I have a rm-p311 remote can it be programed to run a newer unit
Sony remotes keep the same codes for all there tvs. It will run older as well as the newest tvs. Hope this helps.
May 10, 2011 | Sony RM-P311 Remote Control
I just bought a Deluxe VM .... when I plug it in, the red delay light is on....and everything has delay on it. When I press the little white button on the amp in or out, the red light on the amp still...
i guess the switch is broken - if you are not experienced fixing those problems better bring it to a shop and tell them about the problem - i guess they will be able to fix it easily
Feb 25, 2011 | Fender Deluxe VM Tube Amplifier
The delay start light on my washer is on and I do not want to delay start. I have pushed the cancel button twice like instructions say and once I hit start, the delay start light is on and machine is...
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
Nov 23, 2010 | Frigidaire FTF2140FS Front Load Washer /...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
User issue
push the delay wash button until the light goes off
May 02, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Panel lights are on. push on button nothing happens
I have experienced the same thing a number of times. To solve, open the door, then turn the knob, and push the start button on and off, and push the delayed start button (3, 6, 12 hour). Then close the door, and retry. This routine seems to reset the system.
Apr 22, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Concord Fans RM-100 Remote Control Logo
Top Concord Fans Televison & Video Experts
Are you a Concord Fans Televison and Video Expert? Answer questions, earn points and help others
