Question about Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV
Sony bravia internet tv has a pink horizontal band across the screen
Peviously noticed light spaced out pink lines but thought this resulted from the internet using the HDMI cable, then about half the screen is now covered with this pink band.
    Sergeant:
  • 247 Answers
If the line is Horizontal then you deffinantly have a cable issue, replace the cable and that should do it, if it continues the problem could be in the port itself, if using HDMI switch to VGA or composite to test this theory. please keep me posted.
Posted on Dec 27, 2013
  • 1768 Answers
SOURCE: sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Posted on Feb 05, 2010
SOURCE: horisonal line across sony bravia kdl52w4100
i have lin down ma tv
Posted on Mar 01, 2010
  • 308 Answers
SOURCE: mY SONY BRAVIA FLAT SCREEN HAS A LINE ACROSS THE
Sounds like someone hit and broke the screen. Not repairable and not a warranty claim...
Posted on Mar 26, 2010
Testimonial: "not your fault that Sony robbed me blind with crappy product"
SOURCE: Sony kdl-v40xbr1 has horizontal lines
I'm having the same problem. I have noticed on mine that the menu when brought up is clear and I can see it perfectly. The picture on all the inputs is just as described above though. BUT, like I said I can see the menu just fine. This leads me to believe that it's not the panel. Anyone have a solution to this, or at least know what could be causing it?
Posted on Sep 24, 2010
SOURCE: have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Posted on Oct 18, 2010
Sony Bravia will have horizontal bands going across the screen until tv warms up
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 30, 2014 | Televison & Video
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
JVC 36" color sterio tv lines on top of screen
does the problem occur while watching dvds. it is possible that it is an issue with your tv but i would try switching off of cable to a game console or dvd before i said for sure it was the tv. you also might try using another port on your tv such as hdmi, s video, rca or componet ports . if any of those ports work i would replace my cable from the cable outlet.
Feb 17, 2012 | Computers & Internet
I have purchased Sony Bravia LCD BX 42, which has a very thin horizontal line across the screen, how to fix the problem
my sony bravia BX42 has a color green horizontal line and it makes bigger and bigger until some color pink was appeared then I am worried if it will not turn to normal as it goes :(
Aug 29, 2011 | Sony BRAVIA KDL52XBR2 Television
What causes horizontal lines across tv screen
The horizontal lines on the screen is a symptom of failing LCD panel, it will get more lines as time goes by.
Dec 12, 2010 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
I have a 5 yr old Samsung HP-R5012 Plasma Display Television. A display model. Last night, horizontal lines appeared, then, the top half of the screen went black, with color pink and blue surrounding the...
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 11, 2010 | Samsung HP-R4262 42 in. Plasma Television
Have horizontal lines across the screen and some
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
Sony kdl-40v5100 has handshake problem
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV Logo
271 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
