Question about Dell Inspiron 1525 Notebook
Wireless network Trying to keep wireless connection after shutdown, have to keep reconnecting when switched on
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 59 Answers
Assuming you are using Windows 7, connect to your wireless network, click the signal bars, right click your wireless connection and select properties. Select the Connection tab and make sure
Connect automatically when this network is in range is selected.
wireless network - nqaakhh4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaucn9f4k8oqqzjcdlaaaaaelftksuqmcc
Posted on Dec 28, 2013
3 Suggested Answers
kisssmooth
  • 92 Answers
SOURCE: trying to install wireless network. Wireless
if you're using windows XP then you need to start the Wireless Zero Configuration. just click on the start button and choose run then type in services.msc in the run box and click on ok. in the services window just look for Wireless Zero Configuration, it's at the bottom part of the list. just double click it and under the General tab you'll see a box for the Start up type, just set it to Automatic and then on the Service status click Start and then Ok button. once you finish this, you will be able to see the Wireless network tab to be able to select the "use windows to configure my network". in case you're using vista, that option is actually not available as it automatically starts the windows wireless manager and only conflicts if there is a third party software/ wireless manager installed in your computer.
hope this helps...
Posted on Nov 24, 2009
Testimonial: "Thanks -- that solved the problem !"
  • 13 Answers
SOURCE: cannot connect to wireless networks, where is
First of all check these are ok: Check your network adapter settings to see if you have your wireless card enabled. If that is ok, see if you can pick up any other wifi access points apart from your own. If you can see others fine, this means your wifi card is working correctly. If you can see your own access point and not connect to it, check the signal strength, items like microwaves and cordless phones can interfere with the signal. If you have a good signal try connecting. If it is asking for a key/password, then you will need to find the authentication key for your wireless access point.
If you cannot see your wifi access point but can see others, then you may have SSID broadcasting disabled, or the wifi might not be functioning correctly. Check these in your access point settings.
Posted on May 20, 2010
MY NOTEBOOK WON'T ALLOW MW TO CONNECT TO THE INTERNET. iT KEEPS TELLING ME THAT I need reconnect my internet exployer. It keeps telling me that I can't connect with internet explorer. But I...
Hi!
There are many possible reasons why you can't connect to the internet and answering these questions might help narrow down your problem.
  1. Are you trying to connect to the internet wirelessly or with a wire?
  2. If you are connecting wirelessly, are you connected to any wireless network or did you enter the encryption key correctly?
  3. If you can't detect any wireless network then check if the wireless function of your laptop is enabled or not. That can be found as a slide switch at the side of your g550.
  4. What operating system are you using? Windows Vista, XP?
I hope you will find this helpful.
Thanks!
Jun 14, 2011 | Lenovo Computers & Internet
Sony laptop won't reconnect to wireless router
First check your wi fi switch is on in laptop.
Second also check that your wi fi network padapter found your router netwrok in my netrwork places.
Then when u cliko n connect what happen let me know please.
Jun 14, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
Keep getting disconnected
someone continue to stop my wireless connection from his own pc
Apr 06, 2009 | 2wire (1000-100016-002) Wireless Adapter
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
Cannot connect
If you're trying to connect wirelessly, you probably need to disconnect from the wireless network in the wireless network manager and reconnect. This will force you to re-type the wireless access key. If you have the correct wireless key, it should connect and give you an IP.
If you're connecting using a network cable, your network connection settings may need to be change so that your computer will get an IP address automatically.
Jan 31, 2009 | Belkin (F5D7230-4) Router (587009)
No internet access
Check if the wireless network is connected properly in the laptop, try to disconnect the connection , and reconnect again ..if you still feel you are connected..at the lower right hand corner you will find the wireless network connection icon..right click the icon and click view available wireless networks, check you are connected..if yes click change the order of the preffered networksand remove your wireless network and then try connecting it..try it out and let me know...all the best
Jul 29, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Reconnection to my new computer
do you have a wireless network card on your desktop pc?
you have to configure your wireless network card properly
Apr 07, 2008 | Computers & Internet
Wireless connection cuts in and out
uslay gota change chs in option menu keep trying these are very bugy stiill ok
Feb 09, 2008 | Linksys Wireless-N WRT150N Router
2Wire router
if your wireless connection is not working even if the wireless light is lit up on ur 2wire modem/router....try to delete the 2wire network from the prefered list...go to network connection, right click on wireless netwrok connection, go to properties and click on wireless network..select the 2wire netwrok on the prefered list and remove..reconnect to the network by clicking on view available wireless netwrok and select the 2wire network again...if its asking for a WEP key or password take a look at the bottom on the modem a 10 digits number enclosed in brachets..thats the network or wep key. access 192.168.1.254 and click on home network, got to wireless settings---edit settings...change ur wireless channel to 10 adn power settings to 10, save ur changes=)...ohh and by the way make sure that the wifi switch of ur laptop is turned on=)
Jun 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Dell Inspiron 1525 Notebook Logo
35 people viewed this question
Alun Cox
