Printer manual
SOURCE: pixma MP160 has service error 5100
5100 says the carriage is not free to move all the way left and right, or there is ink or grease on the encoder strip, the plastic strip behind the carriage assembly. You can clean the strip with a Q-tip just damp with water.
Testimonial: "Thank you so much. Once I knew what to look for I did see a big glob of ink. I carefully cleaned id and it works!!! Thank a bunch."
SOURCE: printer error 5100
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
