Question about Nordic Track NordicTrack T5 zi Treadmill
Motor is burned out - Nordic Track NordicTrack T5 zi Treadmill
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
You can buy used parts at www.usedtreadmillrepairparts.com
Posted on Jan 04, 2014
D24000 wet tile saw smells of burning. What could this be?
mmm.. motor problem,armature or field coil burned or bearing burn motor housing
Jun 03, 2012 | Dewalt D24000S Heavy-Duty 10-inch Wet Tile...
Ruud achiever 10 inside blower motor burning
Check fan cage to make sure it turns freely. Check voltage to IFM make sure it is correct for the application. Make sure the motor turns the fan cage in the correct direction. IFM will have high and low speed make sure when you change from fan on to auto that the motor changes speed. If you have an amp draw meter check to see when running the motor pulls the amp load it is rated for. Recheck all wiring.
Feb 29, 2012 | Ruud Matching Split Air Conditioner
Fuse burned out on motor control board is the fuse the only problem
The fused burned out not because it is faulty but because a problem occurred, probably a short circuit, which resulted in the high-inrush of current. This burning out of the fuse on the motor controller module usually caused by faulty drain pump motor. Water leaks in the drain pump damages the pump motor winding and results in short circuit which eventually burns out the fuse. The drain pump must be checked first for such condition and replaced if necessary before replacing the fuse or the motor control board for that matter.
Jul 15, 2011 | Fisher and Paykel Washing Machines
Motor burned up, replaced motor now it will not start. could it be the capacitor?
I just had an issue where I thought the motor burned up. It turned out that the red wire from the motor start capacitor to the Motor switch was poorly attached. It became detached midwash and when the motor was supposed to start next I must have got an arc of some kind and thought the motor had burned out due to the smell.
Check the red wire from the motor start capacitor and make sure it has not detached from the plastic wiring harness/pin plug that plugs in to the motor switch. Detach the paper face plate of the motor switch and make sure the connectors are not fried.
Oct 20, 2010 | Kenmore 22422 Top Load Washer
Burning smell from motor
Check your filter and also check that nothing got pulled into the motor...otherwise the motor is burning up and will need to be replaced... probably cheaper to replace the whole vacuum..
heatman101
Aug 27, 2010 | Numatic HVR200P Bagged Canister Vacuum
Necchi Model 535 FA - Replaced drive belt, after running machine for approximately 5 minutes, machine locks down with motor running, motor pully burns plastic belt into.
The motor is running.That is confirmed that motor is fine.But the wires from motor has to be checked.the motor connections are getting short and this is causing the plastic belt to burn.Check the motor as well as its connection.
thanks.
Jun 05, 2010 | Necchi Sewing Machines
Dryer does not tumble -had a burning smell - just clicking when I hit start
The motor has gone bad on your dryer...
The burning smell was the motor burning up..
You will need to replace the motor...
Here is a tip I wrote about your problem....
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 28, 2010 | Frigidaire Electric Dryer
DEAR FRIEND..OUR TREADMILL SA 1060..1.8HP STOPPED WORKING ALL OF A SUDDEN AND WE PRESUME THE MOTOR HAS GOT BURNED AS THERE WAS A BURNING SMELL EMANATING SOON AFTER IT STOPPED RUNNING..WE LIVE IN ABU...
An visual inspection must be made under the motor hood. First unplugged unit then remove motor shroud clean any dirt or debris.Then check for any visible signs of burning on the Motor Control Board. Also check in the front where the power switch is, that may have burned if not, there should be a main fuse holder that also could burn or fuse may have opened up. If the fuse holder is good then proceed to the fuse if it has opened up replace the fuse. Then plug unit back in while you are look at all components while someone initiate start-up and if any burning is visible then isolate what component is burning or arching. Then go to Sports Art Fitness.com go to customer service and get their international number and they should be able assist you.
Feb 27, 2010 | Exercise & Fitness
Humming sound and buring electrical smell
yes yes yes .you are absolutely right.its the coils in the motor burning.the motor needs replacement. Often the start relay for the motor sticks and makes the motor get too hot. This can cause the motor to over-heat and shut off on the built in safety sensor inside the motor. You may need to use a amp probe to test the motor properly, check model plate for proper amps.  If this is let go too long the motor windings can also be damaged ( they may look black instead of a nice copper color). The wires on the relay are also bad for burning off the wire terminals.   The wires at the motor should be checked to make sure they have not burned off or you can test the motor continuity with an ohm meter. See two newmotor wiring pictures.....here...and...here. The relay wires often burn off as well.
May 12, 2009 | Kenmore Washing Machines
Burning smell and smoke from motor
Sounds like the transmission is jammed.  This will cause the motor to bog and burn.
Nov 26, 2008 | Maytag Dependable Clean Top MAV5920EWW Top...
Nordic Track NordicTrack T5 zi Treadmill Logo
48 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
