Question about AT&T 5.8GHz Cordless Phone System with Digital Answering Machine
My answering machine is not recording incoming messages
AT&T 5-8GHz
4 Suggested Answers
richa33
  • 71 Answers
SOURCE: AT&T Answering Machine Model 1717
It maybe hardware issue. Make sure the recording DTAM chip is working. You can try to record your personal annoucement, to see if the chip still record message.
Posted on Jan 21, 2009
  • 5166 Answers
SOURCE: it will record my message and answer incoming call
Usually this is a sign that the unit is in Announce Only (AO) mode.
To check the setting, press Options. Then use the softkey to select Ans Sys. Next select the line for which you want to check the setting (L1 or L2). Use the up/down (Call List) arrows to choose the current message type (A, B, C, or AO). Press Play/Stop to play this message or select Record to record a new message. To save desires the outgoing message announcement setting, press OK after you select A, B, C, or AO. Repeat this for the second phone line if you have a two line system.
A default message is available for the outgoing messages A, B and C. If you select one of these message types and do not record your own message, the default message will play.
The manual is available at retrevo here: http://www.retrevo.com/support/AT%26T-1782-manual/id/473bh051/t/2/ . You will need to enter a code to access the file.
I hope this helps.
Posted on Apr 13, 2011
joeguest2
  • 2080 Answers
SOURCE: Our machine has dropped our
Here is the direct link to the User's Manual for that phone:
http://att.vtp-media.com/ecp/documents/product_Product/1370/UserManual/5849/E5811_manual_I6.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 29 of the manual for complete details on the operation of the answering machine feature of your phone.
Also be sure that you do not have a separate VOICEMAIL feature from your phone service provider activated on your phone line at the same time. If you also have this type of VOICEMAIL service activated, then it has nothing to do with the answering machne built into your phone and will have different messages and will be controlled seperately by dialing an access number. The VOICEMAIL service may be picking up the incoming calls before your telephone answering machine does. If so, then you will have to get the instructions for the voicemail feature from your telephone service provider.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Posted on Sep 09, 2011
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
Record messages
Make sure it's in the "Answer" mode, not the "Announce" mode. The Announce mode merely plays an outgoing message but does not record an incoming message. The Answer mode does record incoming messages.
Since you declined to specify the model of your Uniden phone I can't tell you exactly how to switch modes. Select the model of your phone from the list beginning here to download a copy of the manual.
Mar 19, 2012 | Uniden 5.8GHz Expandable Cordless Phone...
I have a Uniden cordless answer machine,Can my meesages be retived?
You can operate your answering system from a remote location using any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even to record a new greeting message.
  1. Call your telephone number.
  2. During the greeting message, press 0 and enter your PIN code. By default, the pin code is "80" without the quotes.
  3. The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two. For help, press one zero".
Available commands are:
  • 0 then 1 Repeat a Message
  • 0 then 2 Playing Incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop*
  • 0 then 8 Greeting Message Record/Stop*
  • 0 then 9 Answer System Off
  • 1 then 0 Help Guidance
Jan 23, 2011 | Office Equipment & Supplies
We have a 5.8 ghz vtech phone with answering machine. where the clock display is - there is an A. what does that mean?
That means your system is set to "announce" mode, where it plays an outgoing announcement but does not record any incoming messages. The alternative is "record" mode, which plays an outgoing message and then records the incoming message.
Since you didn't specify the model of your VTech system, I can only direct you to enter it into the search box here and download a copy of the manual.
Dec 26, 2010 | Vtech Lands Phones
I have a 5.8 vtech cordless phone and answering machine combo. The answering machine has a Ain the screen and doesn't record incoming messages.
Your machine is set to the announce mode, where it plays an outgoing announcement but does not record incoming messages. You want to switch it to the record mode. Since you declined to specify the model of your VTech system I can't tell you exactly how to do that. I can direct you to enter the model number into the search box here to download a copy of the manual.
Nov 12, 2010 | Vtech Lands Phones
Not recording
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only)
3) Press the OK soft key. You will hear a confirmation tone.
Feb 02, 2009 | Uniden TRU8885 Digital Answering Machine
No Recording
Make sure the answer mechine is ok. Press "On/Off" serveral time. You can try to record your personal memo ,to check if the answer machine can at least record message locally.
Jan 17, 2009 | GE 29875GE Digital Answering Machine
AT&T 5.8GHz Cordless Phone System with Digital Answering Machine Logo
20 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
