Question about iHome iBT60 Bluetooth Rechargeable Mini Speaker System in
Ihome ibt60 wont turn on
I charged the speaker for 5 hours and i go to turn it on but the blue light dtill does not come on. I just got it yesterday so i dont think it would be dead.
Volume on my iHome is too quiet, fix please?
You an inline battery powered signal booster, they are cheap.
Sep 23, 2016 | iHome iBT60 Bluetooth Rechargeable Mini...
Will my ihome Bluetooth speaker work after being wet I have no sound
yes but you need to dry it for 12 hours or it looks dry
and then charge.If its not working charge the one damaged and turn on
Oct 20, 2015 | iHome Audio Players & Recorders
Big blue speaker repair
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
If the speaker is under warranty get it replaced.
Taking the speaker apart to replace the battery will compromise or even destroy the acoustic properties of the speakers. Big Blue Live Wireless Bluetooth Speaker
Mar 09, 2015 | Brookstone Big Blue Studio Wireless...
My iHome iBT60 has a low volume when connected through Bluetooth. I've tried connecting & reconnecting it twice, and it didn't work. Has anybody had success troubleshooting thi
Turn up the volume on your iPhone. Also, try connecting your iPhone or any other media player, e.g. computer, to the AUX IN jack on the speaker and see if the volume is higher for that connection.
Jan 01, 2015 | iHome iBT60 Bluetooth Rechargeable Mini...
I have a ihome ibn27 i charge the blue light comes on when it is connected with my phone but the speakers just make a buzzing sound and wont play
Turn up the the volume on the speaker and your phone. Also, did you make a phone call to check if it goes through the speaker ?
Oct 09, 2014 | Audio Players & Recorders
My speaker won't play at full volume in blue tooth, why
Disconnect it then reconnect it and it will be back to new
Apr 24, 2014 | iHome iBT60 Bluetooth Rechargeable Mini...
Bluetooth problem ibt60 to iphone5s
Had the same problem if you have barely any sound when wirelessly playing music go to Bluetooth in setting and forget the device then turn the speaker on and off then pair it again Works just fine
Dec 01, 2013 | iHome iBT60 Bluetooth Rechargeable Mini...
Ihome ip87 it wont turn on it only charge my itouch?
If unit is plugged in and doesn't respond, try resetting the unit by
following these steps:
a) remove iPhone/iPod from dock
b) unplug unit from power source
c) remove back up batteries
d) wait 1 hour, then resume use
Jun 03, 2011 | SDI iHome2Go (IH80B) (Black) Docking...
iHome iBT60 Bluetooth Rechargeable Mini Speaker System in Logo
159 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
