Question about Dryers
I have a little beeping sound occurring on my iPad mini it happens about every 25 secs and I've turned of all the sound things in notification center
  • Dryers Master
  • 8,220 Answers
Low battery?
Posted on Dec 27, 2013
I cannot see notifications on the notification page even though I have been notified about new messages on this page ... HELP
You could possibly go to settings>notifications and change notifications for each app.
Jun 13, 2016 | Apple iPad Mini
Music sound is gone when I play my iPad mini
This can only be one of 3 things:
1) iPad needs a reset - Press and hold the Sleep/Wake button until the red slider appears. Drag the slider to turn your device completely off. After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
2) Toggle the 'Silence' switch on the side of the iPad and turn up the volume
3) If the above two doesn't work, then it is most likely that your speaker isn't working.
Sep 27, 2015 | Apple iPad Mini
I used to get audible notifications re texts but now I don't
firstly check if your volume is not all the way by going to the home screen and increasing the volume.
second go to the setting then notifications and check the app in question it might have auto turned off with an update or something.
PS: I haven't used an apple device in a long time but im pretty sure its in the setting the under 'notifications' if not there then maybe under the 'sounds' tab
Mar 10, 2015 | Apple iPad Mini
Certain apps that need wifi don't work even though I have perfect wifi signal. I've already restarted my iPad mini, charged it, and turned on and of the wifi a few times, but that didn't help
Possibly one app is locking up networking... My gf had this problem after ios update to 8.0. It turned out facebook app became messed up. I uninstalked facebook and everything was great. Reinstalled facebook and it worked fine after that...In fact her whole ipad got faster... IOS updates are becoming painful...
Dec 30, 2014 | Apple iPad mini 7.9" 16 GB Wi-Fi 4G White...
How do I get rid of a silly graphic weather widget which overrides my weather photos after I accepted it?
Adding & Removing Widgets and Items from iOS Notification Center
Don't care to see Reminders or Stocks in your Notifications screen? You can add or remove anything:
  1. If you haven't already, unlock the iOS device swipe down to bring about Notifications panel
  2. Select the "Today" tab and choose "Edit" at the bottom of the list
    • Delete Widgets from Notifications: Tap the red (-) minus buttons alongside items to remove them from the Notification panel
    • Add Widgets to Notifications: Tap the green (+) plus button to add a widget to Notification Center
  3. Choose the "Done" button in the upper corner to set the changes in place
Any adjustments made to Notifications Center here will be visible when accessed from either the lock screen or elsewhere in iOS.
Dec 07, 2014 | Apple iPad 32 GB WiFi Tablet PC
How do I get the sound on my ipad apple 16gb
Go into settings: notification center : check your apps to make sure the sound is on for that app.
Sep 15, 2014 | Apple iPad (16 GB) WiFi Tablet PC
No sound on ipad
1. If you have no sound at all, even in the Music App, try rebooting the iPad.
Reboot the iPad by holding down on the sleep and home buttons at the same time for about 10-15 seconds until the Apple Logo appears - ignore the red slider if it appears on the screen - let go of the buttons. Let the iPad start up.
2. If you lost sounds for keyboard clicks, games or other apps, email notifications and other notifications, system sounds may have been muted.
System sounds can be muted and controlled two different ways. The screen lock rotation can be controlled in the same manner as well.
Settings>General>Use Side Switch to: Mute System sounds. If this option is selected, the switch on the side of the iPad above the volume rocker will mute system sounds.
If you choose Lock Screen Rotation, then the switch locks the screen. If the screen is locked, you will see a lock icon in the upper right corner next to the battery indicator gauge.
If you have the side switch set to lock screen rotation then the system sound control is in the control center. Swipe up from the bottom of the screen to get to control center . Tap on the bell icon and system sounds will return.
If you have the side switch set to mute system sounds, then the screen lock can be accessed in the same manner as described above.
This support article from Apple explains how the side switch works.
http://support.apple.com/kb/HT4085
3. Try cleaning the dock connector opening of the iPad with a soft brush and just a little bit of rubbing alcohol.
4. Reset all settings. Settings>General>Reset>Reset All Settings.
Aug 12, 2014 | iHome Ipad/ipod/iphone Rechargeable Mini...
Ipad mini wont on after pushing the home button
try removing the battery for several minutes , them put back in
Apr 05, 2014 | Apple iPad (16 GB) WiFi Tablet PC
App notifications on iPad
Notification Center settings: define what's shown To access Notification Center's settings, navigate to Settings > Notification Center. From there, you can select what elements which appear under the Today view. You can also disable or set how Notification Center alerts you for each of your App's notifications: via a banner or via a pop-up message.
app-notifications-ipad-0tb34kwmyoceio04eaynqm4i-4-1.jpg iOS 7s Revamped Notification Center app-notifications-ipad-0tb34kwmyoceio04eaynqm4i-4-6.jpg
Feb 26, 2014 | Computers & Internet
Volume stuck on mute for wireless speakers
After pairing it, have you tried to go to your sound settings in Control Panel and selecting the bluetooth device as your standard sound device?
Oct 25, 2012 | Computers & Internet
Dryers Logo
41 people viewed this question
Top Dryers Experts
