Question about Garden
How do I verify spark is working?
My JD 240 with Kawasaki fc240v 14 hp wont start. I tried to verify spark by pulling the plug out and attaching it to the wire then engaging the starter. No spark. Is this a valid way to verify whether or not I am getting spark?
  • 3 Answers
There are spark (iginition) testers available, but the simplest way is to do what you are doing, plus a step. If you aren't grounding out the bottom "L" shaped part of the spark plug to a metal part of the engine, then you won't get any spark. So, here you go...
1. Remove spark plug.
2. Attach spark plug to wire.
3. Ground spark plug to metal (place the "L" on the engine block, etc... make sure no paint is in the way, it needs metal to metal contact.
4. Keep plug grounded and have a buddy crank the starter. That way you can really get a good look at the plug.
Best of luck!
ChicoTico
Posted on May 18, 2009
    Problem Solver:
  • 7 Answers
Well it probably best if you change places with your buddy you can get a big jolt from the spark, the tool cost under 5 dollars and you wont have to share a beer with a buddy .. kinda pays for itself...jim
Posted on Jul 13, 2014
My 240 volt 13 HP generator wont start
Check spark plug sparks OK. Check fuel.
If you unscrew the spark plug you should be able to smell fuel on it. Also trying to start it when it's out but plugged in you will see a little blue spark, or should do. Don't hold it whilest doing this.
Oct 22, 2017 | HP Electrical Supplies
Howto change coil on a kawasaki 422 in a jd 240 mower
use some sort of lube like silicone spray
Nov 18, 2014 | kawasaki Garden
My aura 125 stop in the middle of my way and cannot start the battery is ok the spark plug changed a new one but still cannot start.
You need to verify whether you have spark. Pull plug and hook up to plug wire. Ground spark plug by threads and turn engine over. You should see spark at the tip of plug.
May 26, 2013 | kawasaki KSR 110 Motorcycles
JD X-475 runs terrible after new spark plugs
maybe you have a carb problem and that's why the plug get fouled out
Jul 12, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Ran out of gas,put 4 gals in wont start tried starting fluied wont start
Sounds like the ignition system is not firing the spark plugs if starting fluid and gasoline doesn't solve the problem.
Verify by putting a spark tester on one of the spark plug boots and attaching the spark tester to the engine block or ground.
Dec 18, 2010 | 2006 Nissan Frontier
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Ksf 400a1 4 wheeler wont start even when pulled gets fuel has spark was riding on wheely when it stopped running hasnt started since
it may be flooding out that is why it wont start try to shut the fuel off and try to see if it will try to start if not try taking the spark plug out and putting a little bit a very little bit of gas in the plug hole and then put the plug back in it and try to start it
Jul 16, 2009 | kawasaki Full Suspension Mountain Bike Men
Kawasaki 636 2005 wont start
What do you mean by nothing? Have you verified spark, fuel?
Apr 03, 2009 | 2001 kawasaki ZX-6R Ninja
JD mower-only one coil firing
I just switched the coils around. The other cylinder went dead, so I knew I had a bad coil. Replaced the coil and mower runs great.
Apr 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Kawasaki electrical fault,immobiliser not working
Wow...where to begin, I am not a professional mechanic...but I've been buying and rebuilding bikes for over a year now and I've encountered some of these issues.
Q: do you have the original key and ignition still in tact?
the fuel pump and choke you should hear activate when you turn on the ignition and/or press the start button...the fuel pump should be located in the gas tank, there should aslo be a single connector w/2 wires that attaches to the fuel pump...I'd suggest checking that FIRST, in a Kawasaki I dont believe that the F1 light blinks when the ignition is switched to off so do not let that be decieving to you...Another easy fix and hugely overlooked and misunderstood issue is the battery...by this It means that a bike will not have enough "stable power" to "fire" or "spark" a coil, so other than a new battery or a strong jump start you will be unable to determine whether or not there is an actual CDI or ignition issue to contend with...after checking and verifying those issues, please feel free to find me and I'd be happy to share the many small things I've had to contend with
Dec 14, 2008 | 2006 kawasaki ZX-14
Garden Logo
369 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
