Question about GE Spectra JBP78 Electric Kitchen Range
Oven door hinge broken spectra - GE Spectra JBP78 Electric Kitchen Range
3 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
Posted on May 23, 2009
  • 1891 Answers
SOURCE: repalce a broken door hinge on upper oven
you must remove side panel . if wall oven slide out on a table strong enough to support is during service . mm
Posted on Jul 16, 2010
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
How do I know if the hinge is broken on the stove door?
the door will fall off when opened if both hinges are broken, if only one hinge is broken the door will drop down on one side.
Apr 20, 2012 | Brown Stove Works Ovens
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
The oven door came off and I can't get it back on?
Hi, open both hinges one click or about 45 degrees, slide the door on both hinges simultaneously. Good luck
Jan 13, 2010 | GE Spectra JBP78 Electric Kitchen Range
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
May 23, 2009 | GE Ovens
I need to remove oven door, cant figure out how
drop the door down as low as it will go look carefully at the hinges as they pass through into the oven chassis you will see a clip on each one that you lift up to lock the hinge you usually lift them up as far as they will go then this will lock the hinges as you close the door the hinges will come away from the oven complete with door.... reverse to refit.
May 06, 2009 | Bosch HBL 755 Stainless Steel Electric...
GE Spectra JBP78 Electric Kitchen Range Logo
16 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
