Question about Audecom Bluetooth Speaker For Your Phone
My audecom bluetooth spb-2800 speaker phone won't pair
Won't pair
How to pair apple phone to speaker.
Turn on the speaker, hit the Bluetooth pairing button on the speaker, go to settings on your iphone, then click the Bluetooth menu on your iphone, turn on Bluetooth and then click on the speaker description as it pops up near the bottom of the menu. You should be connected if this is a Bluetooth speaker.
Feb 18, 2017 | Apple Cell Phones
I can't pair my phone with a bluetooth speaker.
Switch speaker OFF. Power phone down count to 10 and power back up. Go to Phone, Settings - Bluetooth - Search for Devices. Turn Bluetooth speakers on. When found by the phone, click PAIR. If asked for a PIN Code, the default is 0000 (four x zeros).
Any problems COMMENT below my name with make and model of phone and make and model of speaker.
Jul 05, 2016 | Cell Phones
When I am trying to pair my smart phone with my ISBW2113 speakers I am getting an error: Unable to pair with ISBW2113. Incorrect PIN or password?
default is usually 4 zeros
yep it is. You must only have one entry on your phone for them. Manual is listed, details on page 2.
Pairing the Speakers (This process should be done FIRST before pairing a Bluetooth device. This should only need to be done upon first use.) 1. Power on the speakers by sliding the power switch to the ON position on both units (first make sure both speakers are fully charged). The Bluetooth Indicator and Speaker Connection Indicator will flash slowly in unison. If the Speaker Connection Indicator is not flashing, but is solid white both speakers your speakers are already paired. You can skip to the Pairing a Bluetooth Device section. 2. Press the Connect Speakers button on both speakers simultaneously. The Speaker Connection Indicators will flash quickly. Wait until both Speaker Connection 3. Indicators are solid white, this means the speakers have been successfully paired. Please note that this process can take up to 1 minute. Note : For all future uses please turn on both speakers and wait for them to connect (it may take up to 1 minute for them to pair automatically even after initial use). There should be no need to press Connect Speaker button again. If any pairing issues should occur, please follow the above steps again. Pairing a Bluetooth Device 1. Make sure you have first followed the instructions for Pairing the Speakers
When pairing, the device should remain within 3 feet of the speakers. 2. Press the Pair button on ONLY one of the speakers. The pair indicator will begin flash quickly. Using the native controls on your Bluetooth device, select the "ISBW2113" in your Bluetooth settings to pair. If your device requests a password, enter the default password " 0 0 0 0 ". Refer to the user's manual for your specific device for instructions on pairing and connecting Bluetooth devices. 3. When successfully paired, the pairing indicator will stop flashing and will remain solid. After initial pairing, the unit will stay paired unless unpaired manually by the user or erased due to a reset of the device. If your device should become unpaired, follow the above steps again. If any pairing issues should occur, un-pair the unit on your Bluetooth device and follow the above steps again. Note : If two speakers with the ISBW2113 name appear on the pairing list of your device, please erase one of ISBW2113 listed in your Bluetooth device and repeat the above steps again. Para descargar este Manual del Usuario en ingl?s, espa?ol y franc?s, o para obtener respuestas a preguntas frecuentes, visite la secci?n de apoyo en www.iLiveElectronics. com Playing Audio Wirelessly 1. Follow the instructions for Pairing a Bluetooth Device. 2. Use the native controls on the connected Bluetooth Device to select a track. 3. To play, pause or skip the selected track, use the native controls on the connected Bluetooth Device. 4. Any audio played through the connected Bluetooth device will now be heard through the speakers. Pour t?l?charger ce guide de l'utilisateur en anglais, espagnol ou fran?ais, ou pour obtenir des r?ponses ? des questions fr?quemment pos?es, consultez la rubrique d'assistance sur www.iLiveElectronics.com Customer Service: 1-888-999-4215
ILive ISBW2113B User Manual Page 2
Jul 04, 2016 | iLive ISBW2113B BLACK WIRELESS BLUTOOTH...
I have purchased 2 of these speakers. I want to Bluetooth connect them to my iphone. How do I do this and get music from both speakers?? Thx
If you have purchased Speakers with Bluetooth Connectivity capability you can do this by switching on the speakers and on your iphone use the Bluetooth Pairing Option from Bluetooth settings to establish connectivity and play music to hear from speakers
Jun 15, 2015 | Audio Players & Recorders
How do i pair my phone to play on my insignia speaker?
1. Press and hold the button to put the speaker in "Pairing/Connecting" mode. You should see a red and blue light flashing in rapid succession somewhere on the speaker.
2. Turn on Bluetooth on the phone and tap on Scan. The phone will start scanning for nearby Bluetooth devices. When you see that it detected a device with a name similar to the speaker's name, tap on the name to pair with the phone. If you are asked for a passcode/passkey, enter '0000' or '1234' (without the quotes). If the two pair, the light on the speaker will turn to a steady blue and you will see 'Connect' on the phone. Tap on Connect and then you will see Connected on the phone. Your phone and the speaker are now connected.
The steps above should be detailed in the set up guide that came with the speaker. There may even be a passkey/code provided in the guide. Use that one for pairing instead of the passkey I suggested above. Please note that pairing is a one-time procedure, required only the first time you are connecting the phone to the speaker, a "get to know you" procedure. After that, you just need to connect the two.
Nov 15, 2014 | Insignia NS-BT400 Portable MP3 Speaker w/...
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
How to pair ny mini bluetooth craig speaker to my
Turn on the bluetooth of your phone first: Go to settings>Wireless and Networks>Enable Bluetooth and disable discovery limit in bluetooth settings. After that make sure the bluetooth in your speaker is on and let your phone search the speaker and let it pair with it after that go into your phone's music player and look for its play options and if you see via bluetooth click it. Just let me know if you need further instructions or you could watch this video showing how he pairs his bluetooth speaker from his phone DBEST London Bluetooth Mini Speaker Review
Oct 16, 2014 | Cell Phones
How do i pair my x-mini kai capsule speaker with my phone?
Where the bluetooth options on your phone will depend on your phone.
So to put the speaker into Bluetooth pairing more slide the power switch to the right hand side. If the speaker has power then a blue light to the right should light up.
Once this is done you will need to find the Bluetooth devices option on your phone. This will be located somewhere under settings - connectivity.
When you locate the device in bluetooth devices, select it then select pair.
If you can't find the bluetooth options on your phone, comment on this answer with the phone name and model and I will see if I can find out for you.
Sep 11, 2014 | Xskn XAM11-B X-mini Kai Capsule Speaker -...
How do i sync my phone to my smps-650 wireless speaker
Turn on the Bluetooth
In Bluetooth Off mode, press and hold the Bluetooth button for about 5 seconds until a beep sound is heard and the Bluetooth button backlight flashes blue.
Press and hold the Bluetooth button for about 7 seconds to change to
Bluetooth pairing (linking) mode. The Bluetooth button backlight will flash blue and red. then go to the Bluetooth settings on your phone and select it there and enter 0000 for the default password
Then go to the bluetoothT
Jul 26, 2014 | Jensen Bluetooth Wireless Stereo Speaker
I have a Motorola t305 speaker for car it won't let me pair it i put in pass code oooo it says it is right code but make sure device is ready and it is solid blue just like it says but still won't pai
I have found that you need to turn off the Bluetooth and the phone or what you are trying to pair with before you pair this will give it a plane start and it should pair
Feb 13, 2013 | Cell Phones
Audecom Bluetooth Speaker For Your Phone Logo
65 people viewed this question
Top Audecom Car Audio & Video Experts
xxxxxx xxx
Are you an Audecom Car Audio and Video Expert? Answer questions, earn points and help others
