Question about Craig Tower Speaker System For iPod, iPhone, iPad - CHT910
I want to connect my icraig stereo tower to my tv to play sound from my playstation
ICraig Tower Stereo system will not turn on from standby
sometimes the system can get a little "rusty" after inactivity. The most common simple solution is to unplug it then plug it back in
Jan 01, 2014 | Craig Tower Speaker System For iPod,...
Icraig tower on standby
My iCraig tower won't come out of standby. The red light for standby is showing, but it won't come on. Also, it had taken to shutting itself off...from the get-go, actually. Any way to fix this?
Apr 21, 2013 | GPS
Sound problems on tv connected to pc tower
try to re-insert the audio in plug..and assign to audio manager a 2 channel audio..
Jun 05, 2012 | Televison & Video
Ipod won't play, says it is.
Does the iPod work when you just use headphones? Did it happen after the first time you plugged it in to the iCraig? It sounds like the iPod got corrupted somehow. You can go to the Settings menu and try doing a reset. It will not delete your data but it will reset the settings in the player.
You can also try hooking it up to iTunes and seeing if you can play the songs from the iPod through iTunes. You may want to use iTunes to restore the firmware to factory but that will wipe it so hopefully you have a backup.
If you want to do that, connect the iPod with iTunes open and when the iPod comes up on the left, click on it once and the info screen will come up. There are 2 buttons on that scree. One is update and the other is restore. I would restore and then reload.
After you do that and you reload the iPod and it is working again, hook it up to the iCraig and see if it does it again. If it does, the iCraig is bad or incompatible.
Jan 01, 2009 | Apple iPod nano 2nd Generation MP3 Player
Want to play my playstation thru my sa ht500 system
You will not be able to get full surround from your Playstation using this home theater system - if you use a red/white composite AV cable and connect it to the area marked TV AUDIO IN on the back of the Panasonic, you will be able to get stereo sound.
-Tha Mp3 Doctor
Dec 21, 2008 | Panasonic SC-HT500 System
TV Sound through stereo speakers while watching tv.
All the above connected method is correct. Need to change the option in the stereo system as md or auillary depends upon the model. Go through user manual for stereo system.
May 27, 2008 | Sony KV-35S42 35" TV
PS3 Surround SOund
go to the audio settings, i'm not sure what it was it was called like linear pcm or something like that...it worked for em
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Craig Tower Speaker System For iPod, iPhone, iPad - CHT910 Logo
117 people viewed this question
Top Craig Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Steve F
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
