Question about Apple Computers & Internet
Will a Fisher MP3/MP4 Digital Player work with an I-mac computer?
The disc that comes with the MP3/MP4 player is only 80mm diameter and will get stuck if I put it in the slot on the side of my iMac. Is there any way to download (copy) a disc for my player from the internet so I can use my MP3 player with my I-mac?
  • 339 Answers
You should be able to download this from the manufacturer's web site.
If not, find a computer with a tray type CD drive and copy the files from the small CD to either a normal size DVD or a thumb drive and you should be in business.
Posted on May 18, 2009
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
It says on the phillips site that the phillips gogear vibe mp3 player supports mp4 but everytime i add files they dont work. is there different types of mp4 files
yes your correct there are different types /size of mp4 s here is a video on Philips site that explains what sizes format are acceptable usually the player comes with a disc that has a free tool to convert videos to proper sizes hope this helps and please vote
Nov 30, 2010 | Philips GOGEAR SA6045 MP3 Player
Describe your element gc-822 error Problem I loaded the songs and they wont play. It says "disc error."
check to see if your files are MP4, vs MP3. MP4 files won't play in this player, so you'd have to convert them to mp3.
Nov 29, 2009 | Sears GC-822 MP3 Player
I recorded two hours of music from the FM radio using my JNC SSFM2 series MP4 player. The firmware version on the player is BKSD01NB22_32 2007-10-30 9.1.52 2005-01-09 When I stop recording I am able...
The recording from radio that did not want to work in iTunes was made in WAV format. To solve the problem I went to settings and changed recording format to MP3. When I recorded in MP3 format from the radio with my JNC SSFM2 series MP4 player and copied it into iTunes on my computer, iTunes played it without a problem.
Apparently WAV format is used on PC and MP3 is used on Apple Mac.
Jan 05, 2009 | JNC Computers SSF-M2 Digital Media Player
My computer will not recognize my Fisher digital MP3/MP4 player
Mattel Consumer Relations Answer Center - Contact UsFor your convenience and assistance, you can contact us via toll-free phone lines. English, French and Spanish speaking agents are available. ...
service.mattel.com/us/ContactUs.aspx - 39k - Cached - Similar pages - contact here richardm69
Jan 03, 2009 | Audio Players & Recorders
Using mp3 player on mac computer
There is no solution - the software is not Mac compatible -period. It doesn't say MAC-compatible on the product specs, therefore it is not Mac compatible.
Aug 22, 2008 | Philips GOGEAR SA6045 MP3 Player
MP4 player
You just need to convert your video to mp4 vide, then plug in your player to computer, copy the mp4 video to your player flash memroy, that's all. If you don't knw how to convert video to mp4 video, here is a step by step guide for you
http://www.top5soft.com/tutorial/how-to-convert-video-dvd-to-ipod-psp-zune-pda-cell-phone.html
Jun 20, 2008 | Apple iPod nano 3rd Generation
My mp3 mp4 player
the songs on and mp4 digital player only playsa song for about 4to 5 seconds then it goes to another song for a very short time again
Feb 21, 2008 | Konaki MP4-NS MP3 Player
Lost download disc
I couldn't find any software that could make your mp4 works, but if you have windows XP you don't need to have a Cd.
The computer by itself recognize it.
Also if you have the cable just plug it in the new computer and he will recognize it if it is windows XP. but if you have Windows Vista you will have to buy the Disc.
I hope my answer helped you .. Thank you
Jan 29, 2008 | Sears TGE MP3 Player
Computers & Internet Logo
242 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
