Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie digital 4.0 game camera wont power up!
Have put new batteries in camera and push the on button even held it for 30 seconds or more and nothing happens!
  • Moultrie Expert
  • 296 Answers
TRY PUSHING TO AIM...IF LASER DOESN'T COME ON, SWITCH MAY HAVE SEPARATED FROM SWITCH TOGGLE
Posted on Feb 17, 2010
I have a M100 camera and it uses batteries in a day even with my moultrie power panel
Are you sure that power supply is coming fine from that power panel? Otherwise it should not use Battery.
Apr 24, 2014 | Moultrie Game Spy M80 Infrared Digital...
Resetting the Moultrie A-5 Game Camera
HARD RESET TAKE OUT BATTERIES SD CARD PUSH THE ON OFF BUTTON FOR ABOUT 5 SECONDS LEFT EVERYTHING OUT FOR 2-5 MINUTES. THEN PUT THE BATTERY BACK IN TURN THE CAMERA ON IT SHOULD SAY NO CARD. THEN TURN IT OFF THEN PUT THE SD CARD BACK AND TRY IT IN THE DARK AREA TO SEE IF THE FLASH WILL GO OFF. IF THAT DOESN'T WORK WILL NEED TO SEND IT IN FOR REPAIRS.
Nov 07, 2013 | Moultrie A-5 Game Camera
Moultrie camera mfh-dgw 2.1 buttons stopped working and reads no battery power with a new battery. Then Poof it shows full battery and then buttons work, then poof battery level shows nothing buttons don't...
Although I am not totally familiar with the camera, I would try a reset. This worked OK for the Canon I got. Like, remove the memory back-up battery, wait for 30 seconds or so and put it back in. This should do a complete reset. There is also the possibility that the back-up battery needs replacing, that could give the same problems. Good Luck.
Sep 25, 2013 | Moultrie MFH-DGS-100 Digital Camera
Moultrie game camera flash will not work. All bulbs light up red but every night picture is so dark
Try doing a hard reset, Turn camera off remove battery's and sd card. With everything out. Push on/off for about 5 sec. Put good battery's in ig. If you using cheap battery's make sure your are using Duracell or Engerzier battery's not rechargeable. Also make sure not using a micro sd card and nothing higher than a class 4 which is the speed of the card not the size. If still need help call with equipment to troubleshoot to Moultire 800653334 option 1 and 1 for a live person.
Aug 31, 2013 | Moultrie A5 Game Spy Low-Glow Infrared...
My camera powers up but I can't get it to take any photos I don't have the manual either - and we have never used it I bought it new
having trouble getting camera powered up. Need to pull batteries and push button then it restarts, but wont take pictures. Like its jambed up. ive tried different sd cards also.
Oct 02, 2010 | Moultrie MFH-DGS-200 Digital Camera
The camera has gone dead--it will not come on when
this has to be a D-40;check that push button is actually contacting push switch on printed-circuit card below..ck connections at that area of pcb...a bad solder job will ruin your day.
Jan 12, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie I40 getting error code 480 and wont go into auto mode
ERROR CODE 000480 ?
If this is correct,it relates to: Camera Mod test failed;(4); and under Memory Test, 8= Comms Error.New batteries(good ones) may fix it...
It' not communicating with memory card..ck it's inserted good..press down until it stays down(press again and it will pop up.
Follow instructions on deleting internal memory before installing SDcard.
Also, make sure cam supports kind of card you're using..at 4gb and larger, they become confusing;i.e., 4/8/16mb...older cams won't support some of these. Also there are HC(high capacity); HD(high definition)don't work in these cams..
I posted this for a fix a few days ago, and it turned out to be brand new bad batteries.
Dec 23, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I have a Moultrie 4.0 game camera. The only thing I can get to come on is the Laser Aim to come. What can i do? I can't even get date time or anything to come. Is this junk or what?
to get the date and time turn it on and then use the up and down arrow keys to set date and time., press the mode button to have the auto handheld shooting mode.select auto, this will automatically detect animals or whatnot. the green lcd light will flash for 30 seconds and then its armed and ready..to use as a hand held just to take pics put the setting on handhead. good luck
Nov 30, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
LCD won't power up, laser works
I have same camera, I assume that you have the switch to setup, hold the on/off button for 10 secs
Oct 05, 2008 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
240 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
