Question about Merona Mossimo Gunmetal Bracelet Watch with Rectangle Case
How to change a battery on a mossimo watch
Model # F6888115 watch using 2 batteries # CR2025
I bought a Windriver watch WR5OM and he didnt have the instructions. I can't find them online anywhere. I was hoping u could help me.
CR2025 is the battery number. I'm guessing the # WR5OM is the maker/ model number. Many items are made by one manufacturer, but have different names.Now that we know what the WR5OM is, work with the 28608 number on searches, even ebay.
Jan 11, 2017 | Cars & Trucks
How to set digital time on nf9024
The battery you require for this NaviForce watch is a CR2025, Instructions can be found at
http://www.banggood.com/Naviforce-NF9024-Military-Dual-Display-Week-Date-Men-Wrist-Watch-p-966427.html
You might need to scroll down the page to find them.
I hope this is useful to you.
Jul 10, 2016 | Watches
Hour, minute and second hands don't work, why?
Yes, there are two batteries in the 19093 (Compendium Hybrid). The first battery (CR2025) is visible as soon as you remove the back cover plate. The CR2025 controls the digital half of the watch and the back light. The second battery is underneath the circuit board that the CR2025 is connected to. There are 6 small screws that will need to be removed to lift the circuit board and gain access to the second battery. The second battery is an SR626SW.
Aug 22, 2014 | Watches
Where do you put the 2 flat batteries for 3D option
the CR2025 batteries go in the glasses.
May 26, 2014 | Televison & Video
How do I change the battery on a Windesign Racing ex3018 watch?
You need a tiny flat screwdriver. Remove the 4 screws on the stainless steel back. There is a little spring clip holding the battery in. Use the tiny screwdriver to unlatch one end of the spring clip. Replace the battery (3 volt lithium Maxell CR2025 or equivalent) positive side up. Re-latch the clip and then replace the back, being careful not to cross thread the screws and secure the back well to keep water out.
Jul 11, 2013 | Watches
Watch battery died. Took out and then lost the factory original battery for my Timex Mens 100 Lap Watch Ironman Watch on way to store. Internal parts to watch don't say what battery number I need. You...
I have a 100 lap Timex Ironman Triathlon Flix watch. It uses a CR2025 battery. It is a thin 3 volt lithium battery. My original was a Panasonic battery. I hope that this helps you, Michael
Nov 17, 2010 | Timex Sports Ironman Triathlon 100-Lap...
I recently bought a Mossimo watch with the analog and digital faces and the analog runs like ****. It keeps stopping and losing minutes. Like won't go accurate for more than an hour. Worse if it's being...
Quite often the battery can be the cause. But note that on some ana/digi watches there will be two batteries. The battery for the analog is usually buried quite deep in the watch and may be best for an expert to replace this. That expert will be able to test the battery first. If the battery is still good then I would suspect that the movement is faulty and may need replacing (although sometimes a bit of de-greaser expertly administered can solve the issue). Good luck.
Sep 20, 2010 | Watches
Getting analog part of Mossimo watch to start
FIXED!!!
As it turned out these Mossimo ANA/DIGI watches use two different batteries, one for the digital part (big) and other for the analog mechanism (small).
Have the watch serviced to change the second battery and VOILA!!!!
Enjoy!
Mivales.
Made in Costa Rica!!
Sep 01, 2008 | Watches
Casio G-Shock G-7100D 200m eData
I suspect the battery is dead. This watch needs a CR2025 battery.
Jul 17, 2017 | Casio G-Shock G7100D-1V Wrist Watch
Merona Mossimo Gunmetal Bracelet Watch with Rectangle Case Logo
59 people viewed this question
Top Merona Clothing Accessories Experts
Da Doc
ray gallant
Are you a Merona Clothing Accessory Expert? Answer questions, earn points and help others
