Question about Zenith Z50PX2D 50 in. Plasma HDTV
Tv was working fine, moved it to another room (with no bumps or bruises)....now it wont power on..., it double clicks like it coming on and then shuts off, all with-in a few seconds
    Sergeant:
  • 247 Answers
Cable issue, check all your cables, and even replace them, test your hardware by using a source that you normally dont use, Like composite or VGA just to see if you get an image.
Posted on Dec 27, 2013
Have a sony Bravia 32L4000 that wont turn on
seems to be fine? replace the main power board
Jul 23, 2017 | Sony KDL32L4000 32 in. LCD HDTV
Mitsubishi tv 50604 worked fine, then it shut off and wont turn on
you have shorted power transistor on power supply
Jun 25, 2012 | Televison & Video
42" westinghouse flat screen wont turn on
Some surge protectors fail just when most needed.
Jun 19, 2017 | Westinghouse TX-52F480S 52 in. LCD TV
None working Polariod FLM 2601.
Hmm,
Might be a bad connection inside set, but might want to get the obvious stuff out of the way first.
1. Verify outlet is working by plugging something else into it.
2. Make sure the ac cord is pushed in all the way into tv. Might not be making good contact.
3. Double check to make sure tv doesn't have a power on/off switch. Some TVs have a power button and also a power switch somewhere on the bottom or back of set that might've been flipped off if there is one.
Apr 26, 2009 | Polaroid FLM-2601 Television
TV won't come on
I have a 32 inch tv was working great then went into standby mode and wont turn back on. I have unplugged and am waiting please help!!!!
May 18, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Computer wont turn on
So, lets say that you have double checked all cables, and everything is plugged in properly. When you hit the power switch on the case, do you hear the computer start then shut down several seconds later? Does the computer refuse to do anything but power a motherboard LED? Also, did the computer (or the person carrying the computer) bump into anything while moving it? The most minor bump can cause many problems.
I would try replacing the power supply with another one from a working PC, but just to make sure that the power supply unit is the problem. If it isn't, make sure all heatsinks are locked down appropriately and making full contact. Other than that, I don't know what you can do.
Dec 30, 2007 | Computers & Internet
Cracked screen and down screen
If the double images are located at the bottom on one side, you might have cracked the mirror inside the set and it has been displaced making the picture in that area bad (especially if the rest of the picture is OK)
Dec 28, 2007 | Philips 60PP9202 60" Rear Projection...
Turns off on its own like it was in sleep mode
Probable bad connect / bad caps in power supply.......
Fixable .....usually about $100.00 in the shop..............T.
Dec 07, 2007 | JVC AV-27D305 27" TV
Power problem?
Try th set in another room, if only to see if this phenomenom happens with other light fixtures or appliances. Would suspect the switching type supply in the TV as suspect if the problem "moves" with the set....accordianman
Oct 20, 2007 | Hitachi 43FDX01B TV
Zenith Z50PX2D 50 in. Plasma HDTV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
