Question about Maytag Washing Machines
No water or agitate
Maytag washer Model LAT1916AAE will not fill with water or agitate. checked water lines good cleaned screens good. checked water valve no volts going to valve. turn timer tub will go in spin mode and also pump come on to pump water out. do you think it maybe a bad timer? open lid in spin mode and stops spinning. lid switch good. any Ideas please. Thank you.
  • Rick Arnett
    Rick Arnett Dec 28, 2013
    Found Bad fuse blown in rear panel was a 4 amp 250v fuse replaced and works fine
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
IS THERE A BLOCKAGE IN THE PUMP OR THE MOTHER BOARD IS FAULTY
Posted on Dec 27, 2013
Testimonial: "found my issue was a blown fuse inside rear panel by the timer. fuse was a 4amp 250v replaced blown fuse and works fine."
  • 319 Answers
SOURCE: maytag washer, lat9606aae only works in delicate cycle and hand washable
Replace it
Posted on Jan 04, 2008
  • 96 Answers
SOURCE: Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
Posted on Mar 13, 2008
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: Washer will not agitate/spin.
The lid switch is fine. The timer needs to be replaced.
Posted on Jul 22, 2009
SOURCE: will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
Posted on Aug 18, 2009
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Dirty inlet screen maytag washer
These models actually don't have a filter so the best way to clean it would be by choosing a cycle which allows th most water to fill up the tub , hot water preferably and add some powdered diswasher detergent.To remove your agitator you will have to pull off the top portion and inside the agitator there is a hailf inch bolt to unscrew and the rest will come off.
Hope this helps
Apr 17, 2013 | Maytag MVWC200XW Washer
Maytag washing machine just stopped filling water and agitating. Spins fine but wont fill.
check screens located on hoses at back of washer. If clean the silinoid is most likely out, be sure to turn water valves off first.
Nov 03, 2011 | Washing Machines
Maytag LSE7806ACE washer won't rinse. Machine fills with water and agitates, spins also. Just won"t rinse......help!!!!!!!
Your washer uses cold water only for the rinse cycle.
Start you washer and put the water temperature switch on 'cold' to see if you have any cold water.
If you find that there is no cold water then turn the water off and remove the cold water hose from the back of the washer.
Once you have the cold water hose removed you will be able to look in the water valve and check the screen. A lot of times the screens get plugged up and need to be cleaned. The screen will just pull out of the valve so you can rinse it out good.
Make sure to put the screen back in place.
If you have no cold water and the screen is clean then you will need to replace the water inlet valve.
Aug 03, 2011 | Washing Machines
My Maytag Centennial will not fill with water on the wash or rinse mode. I can hear it click to tell it to fill but it will not. It does spin. I do have water at the kitchen sink so I know it is not a...
your cold water line to the washer is most likly plugged.shut cold water valve of going to washer remove cold water line from washer clean screen in water inlet valve. the screen is in the valve were the line comes of washer.make sure you put the screen back in as it has to be there. flush out cold water line in bucket before putting it back on washer,, good luck thanks for voting
Mar 24, 2011 | Washing Machines
Model # lat1916aae Matag Washing machine will not rinse. Timer and lid switch has been replaced.
the water inlet valve may be blocked you can either remove hoses that are connected to washer and clean screens they may have sedement from hard water also the inlet valve could be faulty they need to be checked or replaced easy to replace to gain excess remove control panel disconect elec. harness
then remove clip pry with screw driver dislodge clip from hole in cabinet tilt cabinet forward and left it off washer you well see the inlet valve you may want to have a repairman replace if you feel uncomfortable to
do it
Nov 25, 2009 | Maytag PAV2300 Top Load Washer
May 17, 2009 | Washing Machines
Maytag washer will not fill with water. It does agitate and spin
My May Tag model LA 882 washing machine is not draining water. the water remains even after spining and the cycles are longer durations. any advise ?
Mar 31, 2009 | Maytag Washing Machines
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
