Question about Sharper Image Wine Opener, Shaper Image Aerator
Wsi-op200 wine opener will not hold charge and will not pull cork
When motor starts under load, it stops. Unit needs new batteries.
My electric wine opener stopped working with a cork in it
Battery has gone flat or it has overloaded the cork screw motor and you will have to cut the old cork off. Try again once changed the battery
Sep 21, 2017 | Home
Hi, I have a Whal arco, batteries are charged, changed blade but when motor comes against pressure it just stops. Any suggestions? Thanks Lauren
Hey Lauren,
Sometimes when batteries are on there last bit of life they will show fully charged.. they will have the voltage specified, but, not have the amperage needed to drive the tool. It takes minimum amperage to get the blade to spin, but when you put a load on the tool, the battery doesn't have what it takes to handle the load.
It takes amperage to make the tool work under load..not just voltage. Sounds like its time for a new battery.
Mar 23, 2017 | Blade Saws
Oster electric wine opener wont pull out corks. Half of the cork, or part gets stuck up in the unit. Has always worked fine up until day before yesterday. Is is shot? Or cork puller not sharp anymore?
You need to replace the battery pack, pull it out and see what type of cells are used, then build a new battery pack, did this on my own opener and wow it really rocks, lots of power.
Dec 31, 2016 | Oster Refrigerators
Batteries shows fully charged. 24 volt shows 27 volts fully charged but shows RED light when install in mower.
it's never the motor, it's always the batteries.
you are most likely testing the batteries with just a meter and not under load
you will need a tool to put the battery under a load, it will end up costing more than two new batteries.
just replace the pair and you will be fine, i have done enough of these over the last few years.
good luck and you will have no problems with the new batteries.
May 21, 2015 | Electric Earthwise Corded Lawn Mower...
I am wondering how can I tell if my wine opener (WSI-OP200) is fully charged. Is there anything indicates it.
When fully charged the light will be solid green! When charging it will be flashing green!
Jan 01, 2015 | Wine & Spirits
I have a 92 pajero wagon which wont turn over. I turn the key and all I get is clicking. I have checked the fuses battery and starter motor all is fine. it will clutch start, please help
The small wire to the starter is loose or failing to make a good connection it gets enough power ti click the solenoid but not engage the starter
Nov 25, 2014 | 1992 Mitsubishi Pajero
Cork stuck in sharper image wine opener
The black plastic ring is secured on the clear tube that you can see the corkscrew through with four little plastic snap tabs. I used a pair of channel locks to gently pull the ring off those tabs. Once you do that you have access to the inside of the clear tube and can reverse the corkscrew and get your broken cork out. Blow debris out and reassemble. Good as new! Even if you break one tab it should still hold, and if you break multiples use some super glue to hold it in place, that will be your last chance to fix it, but at least you've doubled the life of your toy. Good luck!
Aug 05, 2014 | Home
Plenty of power in the battery but when ignition pressed bike won't start, sounds like starter motor not engaging "clicking"
Check the voltage when under load (starting) if it drops below 9volts then the battery is sulfated and you'll need a new one. I had this recently with my K1100. Battery read 12.8 volts across the terminals but fell to 4 v under load. New battery fixed it.
Jun 11, 2014 | 2004 BMW R 1150 RT (ABS)
Won't pull cork out
Battery may be soft. N/G
If it goes in with No Problem and will not pull out
May 21, 2014 | Waring Pro WO50 Cordless Wine Opener
Sharper Image Wine Opener, Shaper Image Aerator Logo
Top Sharper Image Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Sharper Image Refrigerator Expert? Answer questions, earn points and help others
