Question about Proscan 7-Inch Android Internet Tablet, Capacitive Touch Screen, Android 4.1 Jelly Bean, with Included Case and Keyboard
Setting up PROSCAN 7 tablet to wi fi and the internet for the first time
Trying to set u my tablet for the first time and the user Manuel is not helping me
My tablet will not connect to my internet
Can't connect to Internet through WiFi on Android Tablet/Phone. ... 4.Try to turn off/on Wi-Fi on the device. Turn off Wi-Fi first, [Settings]>>[Wi-Fi] >>[OFF]. Then turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[ON].
Can't connect to Internet through WiFi on Android Tablet/Phone - Asus
www.asus.com/UK/support/FAQ/1003867 https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=tablet%20will%20not%20connect%20to%20my%20internet
Dec 21, 2016 | Tablets & eReaders
Wi-Fi states authentication problem but can't reconnect and it won't give me the chance to input password
delete/forget the wifi connection in the tablet. re do the wifi set up with the proper WEP/WPA password from the router.
Apr 18, 2015 | Proscan 7-Inch Android Internet Tablet,...
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
How do you factory rest this tablet?
Just go Settings > Back up and reset > Factory data reset.
May 10, 2014 | Proscan PLT7035 7" 4 GB Wi-Fi Black Tablet...
Users manual Sanei N79 Android 4.0 3G
A .PDF version of the Sanei N79 user manual in English will be available shortly (Mid Nov 13), if you require a link to it, mail us at nexusgruppe@gmail.com
Jun 10, 2013 | Tablets & eReaders
I cant get my tablet to connect to wifi
Android tablets, unlike Android phones, don't require mobile phone service or a contract with a mobile phone company, and several models use Wi-Fi for network connectivity. The Android 3.0 operating system, known as Honeycomb, is designed specifically for tablets, and has the same features for Wi-Fi connections that are available with earlier versions of Android. Android tablets support wireless connections encrypted by both WEP and the more-secure WPA.
Tap the "Apps" menu on the tablet screen. Touch "Settings." Touch "Wireless and Networks" and select "Wi-Fi Settings." Tap the "Wi-Fi" box to turn on Wi-Fi. The Android tablet scans for available Wi-Fi networks and displays them on-screen under "Wi-Fi Networks." Tap an available Wi-Fi network. Touch "Connect" if it is unsecured, or enter the password or passcode for the encrypted connection.
Tap "Connect."
Jan 14, 2013 | Polaroid 7 in. Internet Tablet
My new zte v9 wont connect to the Internet
you can access the Internet through the mobile network or via Wi-Fi.Your mobile network settings are pre-configured by your serviceprovider and there is no need to change any settings. Wi-Fi Wi-Fi provides wireless Internet access over distances of up to 100meters.1. Tap Home > Settings > Wireless & networks .2. Select the Wi-Fi check box to turn Wi-Fi on
Dec 02, 2012 | ZTE V9 Smartpad Android Internet Tablet
My coby/kyros is not picking up the internet with wi fi
Some devices need the Wi-Fi service turned on/enabled. Please check your devices settings to be sure that Wi-Fi is "On"!
Dec 06, 2011 | Coby Kyros 7" Touchscreen Tablet
Proscan 7-Inch Android Internet Tablet, Capacitive Touch Screen, Android 4.1 Jelly Bean, with Included Case and Keyboard Logo
27 people viewed this question
Top Proscan Tablets & eReaders Experts
CrisO
tosin_christ
David Payne
David Payne
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
