Question about Gateway LX6810-01 PC Desktop
Optical drive wont eject tray
DVD drive tray wont eject, must use pin to force open
2 Suggested Answers
cinek79
  • 320 Answers
SOURCE: I can't eject the optical
hi check the connection between your drive and motherboard also check power connector . Between connectors on the optic drive you need set up a jumper(s) on master or slave. if you can`t open drive in your OS there is a small hol on the front panel of the drive use needle or something similar to open it manualy
Posted on Oct 06, 2008
Samsung Optical Drive SE-208 tray rattling won't eject
if you look on the drawer you will see a little hole.push a pin in the hole and the drawer will open.
Nov 15, 2012 | Samsung Optical Drive SE-208AB/TSBS...
Dvd won't eject. It lights up flashing like wants to open. I tried to eject dvd every way possible ie., computer link, etc
All CD / DVD drives have a Eject Pin Hole. The only thing we need is a paper clip to use it
All we have to do is bend it at the first curve 180 degrees (straitening it out). Then take the second curve and bend it 90 degrees. Now we need to locate the Eject Pin Hole.
Laptop - Notebook CD / DVD drives:
The trays on laptops/notebooks are spring loaded, so all that is needed is to release the locking mechanism. You do not have to insert the paper clip as far as with a desktop CD / DVD drive, as you are not connecting to the gearing under the tray. Gently insert the paper clip into the Eject Pin Hole. Once you feel it make contact, gently push in and the tray will eject immediately. Once done, gently push the tray back inward until it locks back into place.
Desktop CD / DVD drives:
Gently insert the modified paper clip into the Eject Pin Hole until you feel it make contact with the gear underneath the tray. Firmly pressing inward, you will notice the tray to start to move out. Press inward until you have enough room to get your finger under the tray and then pull it out the rest of the way. If you can only get a small portion of the tray out, you can use the other end of the paper clip to gently pry open the tray enough to get your finger under it. Once done, gently push back the tray to the closed position. It will close firmly when the system is powered up.
Mar 14, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
When I Press Eject button the tray does not open. It is also taking too much time during booting.
Use a pin and insert in the emergency eject hole (usually in the center below the tray) and then you can eject the drive tray with force. It is time you planned for a new drive.
Untill then please insert a music CD into the drive tray and leave it there, this will ensure the eject will work (most of the time). Booting time will definitely increase if the drive has issues, reading or responding.
Feb 03, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
DVD will not eject
To eject a disc.
  1. Use the eject option in the menu bar by selecting open from the drop down menu.
  2. Press the eject or F12 key on the keyboard.
  3. Open the drive face plate and insert the end of a paperclip into the small hole under the drive tray area. This will pop the tray open.
Hope this helps. Don't forget to vote or leave feedback, Thanks.
Feb 23, 2010 | Apple eMac G4 Desktop
My dvd drive wont eject since i ripped cd's on windows media player it froze and then wouldnt eject te cd
well on the CD drive u will find a pin hole which is used to eject the drive tray manually so use a pin and try to eject the CD.
good luck
Jan 05, 2010 | Acer (KV.16X04.007) DVD Drive
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
Jul 08, 2009 | Compaq (CDD480172) CD-RW Burner
Cd/dvd drive
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
Sep 19, 2008 | Dell Inspiron 710m Notebook
Cannot eject the DVD drive
u can see a pin hole on the drive just above the open button or the green light...press the button once n poke the hole with a pin ,,,,it ll hit a soft end...continue pressing it with some force....the tray will open...
Dec 30, 2007 | Samsung Int. IDE DVD-ROM 16x Black Bulk...
DVD stuck in drive
try ejecting through my computer then right clicking on the drive and select eject or there should be a little pin hole at the front of the drive to push and force a manual ejection
May 30, 2007 | LaCie (300987U) DVD RW Dual Layer Burner
Gateway LX6810-01 PC Desktop Logo
27 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
