Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
17 inch dell flatscreen monitor stops in its tracks
For some reason the monitor no longer works - it has a power light, but my desktop does not come up on my screen - it is just black!
I recently added skype to my computer, but made no other changes. All cords are in place as are power cords. Any ideas would be greatly appreciated.
Dark Monitor Girl
  • 2 more comments
  • leslie_barth May 18, 2009
    Thank you so much for all of your replies! To complicate matters I am writing on behalf of my 80 year old father who lives in another state so it may take a bit to work through your suggestions - probably with the help of geek squad!
    gough2960 in regards to your request for clarification, I do not currently have a second monitor to test, but like the idea and may see if a colleague has one available.
    benwabnick, in regards to your request for clarification, I will tell my dad to try this tomorrow first thing.
  • Mark Gough May 11, 2010
    Have you tried the monitor on another computer?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    If you unhook the monitor from the PC and turn on the monitor, does it at least show you a self-test screen?
  • 585 Answers
Sounds like most of the monitor's circuitry is working except for the backlight. If you place a flashlight on the screen you may be able to see your desktop items in the light ring around it. This doesn't fix the problem but it will tell what is wrong. The price of some monitors is low enough now to make this one not worth spending on for repairs. You could sell it as broken on ebay and use the proceeds towards one of the new ones.
Posted on May 18, 2009
  • 975 Answers
Usually the problem is in the MAIN POWER BOARD , BEFORE taking it to a repair shop , open the monitor and check for cold solder or burnt solder around where is a transformer , most of the problem is this , hope it helps , AJ
  • Dell Master
  • 1,684 Answers
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the badparts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the newone thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jun 26, 2009
The width of PC screen has suddenley widened, so that data is not viewable, how to I readjust it?.....
Right click on desktop and click screen resolution. Then select the recommended resolution for your monitor and click apply then OK. This sholud solve your problem.
Mar 02, 2014 | Dell 1702FP UltraSharp 17" TFT LCD...
My 22" dell lcd flatscreen monitor just went out
I know it sounds stupid, but check all the cables and connection. Also make sure the cables are in good order.
Now with that out of the way. Is it getting any lights or indications of power at all? If so it could be a cable or connection point.
Worse case senerio, if your not getting any lights or indications of power (sometimes it seems like it should turn on) the monitor may have had a capacitor or power supple unit failure.
LCD can go out like that from long use or heat. If its older than 4 years its possible its done.
You can have someone open it up and check for budging or bad capacitors. This may be a cheaper option if you have someone is town.
Sorry to hear about the monitor. Good luck!
Oct 11, 2011 | Dell Computers & Internet
My DELL flatcreen just went blank and is now flashing yellow light, won't turn on
Check and make sure your connections on the back of the PC are snug...and make sure you have a good connection at the back of the monitor.
Flashing light...is loss of signal.
Good Luck,
Mike
Nov 06, 2009 | Dell 1702FP UltraSharp 17" TFT LCD...
Monitor comes on and displays for a second then goes blank.
New monitor? Does old monitor still work? Did the monitor ever work? did the computer ever work? is power light on computer on? is power light on monitor still on?
Oct 15, 2009 | Dell 1702FP UltraSharp 17" TFT LCD...
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Black rectangle block will not go away on pc monitor[top right]
hi your problem is caused by heat and a faulty power switch board in front which is also connected to usb and front audio first the heat problem download program fan control I8kfanGUI this program is free fan control set you fan speed to max to cool cpu dell made bad design on cooling. net you have to set bios on pc to auto power on pc after power loss unplug pc do not power off by windows now disconnecgt the ribbon cable that connects to front power switch plug pc back in and it will auto boot.pc should have no more problems the little board in front is faulty and dell e510 all have this problem unfortunately you lose usb ports but you get system stable again.
Apr 14, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Jun 19, 2008 | Star Logic 17" LCD Monitor
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
442 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
