Question about AAXA Technologies P4X DLP Pico Projectors
How to do a hard reset on P4 x - AAXA Technologies P4X DLP Pico Projectors
Does it support 1 tera hard disk ??
i think yes try it or find nearest delar to wether the board support or not
Oct 03, 2009 | Asrock P4 COMBO...
P4 3.2ghz runs as 1.6ghz
Have someone (if you dont know how) change the partition setings on the hard drive.
May 27, 2009 | IBM Computers & Internet
How i down load our p4 sound and video drivers
use Original CD driver for your MOBO or you can download it from they homepage
May 10, 2009 | Intel Motherboard
Swapped hard drive into new casw and now it wont boot up
This is due to a hardware conflict.
The system drivers on the hard drive are for the old mother board and devices,You will have to reinstall OS while it is install on the new mother board,The computer cannot boot to a drive that is loaded to another system unless all the devices and drive are identical.
Please rate this a fixya
Feb 13, 2009 | EliteGroup 848P-A Motherboard
Need unlock code for the lg 260 that i bought off ebay
Thanks for choosing fixya.com
For this problem I would contact the seller. Depending on which unlock code your talking about. If its a boot up password you can reset the cmos jumper to clear the password on most boards.
The jumper is usually labeled something like cmospswd but can be very hard to read. Other cases like the one I currently use, have a diagram on the underside of the cover that shows the location of the cmos reset jumper.
To be safe I'd check with the ebay seller first, then consider resetting yourself.
Jei
Dec 17, 2008 | Mgc Server 1U system P4 2.8G LGA775...
Hitachi ide 80G hard disk on pentium 4 pvmm2 motherboard.
no, it can handle an 80Gb. But before you do that reset first the firmware cause it helps your computer to prepare whatever plug and play devices the you may attach to it. or Upgrade your previous firmware to a higher version.
Dec 14, 2008 | Dell Vostro 1500 Notebook
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
AAXA Technologies P4X DLP Pico Projectors Logo
106 people viewed this question
Top AAXA Technologies Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an AAXA Technologies Office Equipment and Supply Expert? Answer questions, earn points and help others
