Question about Ford Red Metal Gumball Machine 11"
Disassembly of a ford vintage gumball machine
How do you fill the globe with gumballs
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: I am looking for an
This WEB site maybe able to assist you.
http://www.gumballmachinefactory.com/
Posted on Jun 10, 2012
How to download manual
To open a .pdf file you use Adobe Acrobat reader. a Doc file you open with Word.
But from what camera do you need a manual?
If you have a manual, try changing the extension of the file to pdf
Jul 07, 2014 | Veho Vcc-003-muvi-gum Gumball 3000 Edition...
The spiral piece in the base broke the first time we used it. how do you get in to repair it
There are a few versions of this unit
If you are lucky your unit will have scews in the base
somtimes the screws are hidden by the rubb feet
or a label
May 03, 2014 | Sweet n Fun Metal 3-Foot Spiral Gumball...
Play doh candy cyclone jammed
Put the crank handle in the down position and then use the arrows on the gears to guide you. The two gears that hold the two spirals should be closest to you. Make the two arrows on the gears point directly at each other(keeping the crank in the down position). The third gear's arrow (furthest from you) should point directly at you bisecting an imaginary line formed by the other two arrows pointing at each other. The idea is to get the spirals lined up so they create a channel for a ball to fit in.
Jan 29, 2013 | Hasbro Play-Doh Sweet Shoppe Candy Cyclone...
RED SWR ALERT LIGHT COMES ON WHEN I KEY UP
In most cases if the mic works the common cause is the transmitter in the mother board is shorting out or not soldered to the board properly. another cause could be that your antenna is too close to the CB and will disrupt the signal.
Oct 14, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Looking for hampton bay sibley 52 in vintage brass ceiling fan 46796
Have Hampton Bay Sibley 52" Ceiling Fan brand new in box for sale. ski 082392467968 vintage brass finish w/ single beige linen globe.
coronaxtr@hotmail.com
Jun 25, 2012 | Dryers
Dropped gumball-sized nut down driver-side intake hole.
As far as the fuel pump goes, rotate the engine by hand. You should be able to do this with a 15/16 socket on the alternator pulley. It will pop up and rotate untill the pump comes up about a half inch, this will make the cam lobe come up to the point where YOU SHOULD NOT BE ABLE TO DROP ANYTHING ELSE IN THE ENGINE. :) when you go back together put the pump back in, being carefull to keep the tappet in the pump, then rotate the engine untill the pump sits flush. With the intake problem there may be a screen in the intake just for this reason, some had this and some didn't and I'm not sure when they started putting them in. If not you need to pull the valve cover, luckely you did this on the drivers side and not the passanger.
Apr 07, 2009 | 1995 Ford F350
Tranny Fluid
I had the same problem. Facing the car it is at the left front way down low. It does not look like a traditional dipstick. It does not have a loop on the top. Instead they have a small white ball a little smaller than a gumball. It drove me crazy trying to find this. It almost looks like some type of grease fitting. Give it a pull and there it is.
Jan 31, 2009 | 1995 Eagle Summit
Fan instructions to disassemble unit to allow changing upper globe bulbs
should be a set of screws around the outer edge, loosen while holding the globe, some globes if there are no screws twist off, be very careful.
Dec 03, 2007 | Dryers
Ford Red Metal Gumball Machine 11" Logo
251 people viewed this question
Top Ford Cooking Experts
fordexpert
Owen Barnes
Are you a Ford Cooking Expert? Answer questions, earn points and help others
