Question about Hitachi C10FSH 10" Dual Bevel Slide Compound withLaser
Braking on miter saw not working
My miter saw brake just stopped working and the saw continues to run quite some time sfter turning off
    Champion:
  • 304 Answers
Try fitting a new set of brushes first otherwise it could be that it needs a new field coil.
Posted on Feb 03, 2014
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
The brake is constantly on. How do I release on 12" dewalt miter saw
A very much high priority specially on the bearing of the motor on the side where the flat belt is driving the saw on. control it the sawblade should have no problem to turn
There is an electrical brake for a short time after release the switch build in the electric field but it has not an electrical-magnet brake like the DW701 miter saw that only released by an electrical activation.
In high priority this should your trouble i think . 1 order number its a 6302V BALL BEARING or equivalent brand can be replaced by your dealer.
Dewallt have many problems on the choosen fan have to short blades and if the fan is melting because of the heat by to long wait for replace then there is only a complete new armature to buy
Oct 20, 2015 | Dewalt Heavy - Duty 12" Double - Bevel...
The blade brake is not working on my miter saw.
Clean your saw ! Use your air compressor with an attachment to get back in the nooks & crannies, blowing all the caked up sawdust out.
Oct 09, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
Makita 2401b
Some mitre saws have extra windings in the field coil so a possibility is a break in this brake coil another possibility is the switch some have a contact that switches the back emf from the field coil to the brake coil when you release the trigger. And believe or it or not some times changing the brushes affects the braking have seen this a few times on the LS1013.
Mar 15, 2014 | Saws
Blade brake dosen't work right away when switch is released. Takes a couple seconds of slow spin then the brake seems to stop the brake. Suggestions?
All blade brakes take a moment to stop the blade. If it were to engage as soon as the switch were released the inertia of the blade would do damage to the saw. Look at videos of your saw on youtube to ensure it is operating the same as others.
Jun 12, 2012 | Ridgid Reconditioned 12 In. Compound Miter...
Where is the blade brake on the miter saw
The brake on electric motor driven tools is the field & armature. When running the switch provides power to both sides/poles of the field through the brushes and armature. When you release the switch half of the field is powered pulling the armature to a stop. If your bladed continues to spin when the switch is released, you need to replace the switch. The Ridgid part number for the proper switch is 503317000.
Mar 06, 2012 | Ridgid Reconditioned 12 In. Compound Miter...
I have an older model black and decker miter saw. How do you change the blade? I can't seem to stop the motor shaft from turning in order to loosen the nut to remove the blade?
Hi, you need to look thoroughly at the casing of the electric motor. Somewhere between the motor and the gearbox is the brake which must be depressed in order to stop the motor from turning. If for some reason you cannot find this brake, use a pair of vise grips and clamp down on the inside of the blade and turn it until it stops. Now you can unbolt you blade. P.S. make sure you know if the thread is reverse or not! Good luck.
Nov 16, 2010 | Black & Decker 12" Dbl Bevel Miter Saw
Dewalt miter saw 12"
no fuse, you can checked the brush holder assy by poping the assy out & checked the bronze terminal if broken.if the holder are ok. check for continuity of the field coil main ac coil & brake coil, main are bigger wire the brake are smaller wire.
Jul 30, 2008 | Electrical Supplies
Hitachi C10FSH 10" Dual Bevel Slide Compound withLaser Logo
331 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
