Question about Belkin Wireless USB Hub
Wireless hub everytime i hook my HDD to my belkin wireless usb hub model number F5L009 i can not use the HDD. Meaning i can not access it.
I had the problem that,even though the hdd connected it would fail after a period of time (video streaming or file transfers). Set up was Samsung Q45 running wireless g connected to a belkin draft N Router. 3 other PCs (all g) using 2 different OS (Vista and Mac) had same problem.
Solution after months of searching, problem solved. Fitted Draft n PCMCIA card, and to ensure it was running at 300Mb had to use WPA PSK + WPA2 PSK security mode . Now works brilliantly and has managed to stream a full HD movie!! The Wireless link is now running faster 10Mbs compared with 4Mbs on g, although not fast it at least enables the HHD to be used in a stable configuration. Problem seems to be that the unit will not work properly unless wireless n link is used.
Posted on Oct 27, 2009
Maybe Belkin doesnt support Wireless USB?
Posted on May 28, 2009
Need windows 8.1 driver for SXUPTTP
It is compatible: http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductDetailsViewer?Name=Belkin%20F5L009%20USB%20Hub&vendor=Belkin&Locale=1033%2C2057%2C3081%2C4105%2C16393&BreadCrumbPath=Belkin%20F5L009&LastSearchTerm=Belkin%2BF5L009&Type=Hardware&tempOsid=Windows%208.1
Try opening device manager (Windows Key + X then select device manager from the dropdown) Find your device: Look under "unknown devices" or "universal serial bus controllers", right click and select update driver software.
Nov 07, 2013 | Belkin Components F5L009 5 Port Network...
Hi I have belkin54g wireless router with model no. F5D7234-4v1. I can't configure my router properly I used to configure it by adding new wireless network, new network connection has been created and its...
Hey dude u might have to update the firmware try this link
http://en-us-support.belkin.com/app/answers/detail/a_id/510/~/f5l009-network-usb-hub---firmware-update
Jan 12, 2011 | Belkin F5D7234-4 Router
I have just installed a BT N mode Hub, and my Belkin Wireless G Universal Range Extender is now not working. Help please!
make sure wireless channel number should be the same on BT hub and on belkin. BT hub is normally on Auto channel change it to a channel number usually 1 and 11 are the best for coverage and then chose the same channel number in belkin.
Mar 19, 2010 | Belkin Wireless G Universal Range...
The Belkin wireless router I am trying to set up is set as an access point and I want to turn it into a secure home network. How can I do this?
You need to provide a model number for the router.
Here is a link to Belkin where you can select your model number and get more help:
http://en-uk-support.belkin.com/app/product/list/q/routers/session/L3NpZC81QURmM0JUag%3D%3D
Feb 03, 2010 | Belkin Wireless-G Plus MIMO Router with...
We have a Belkin USB hub successfully networking 3 printers to two PCs. We are currently making the drastic switch to two new iMacs to replace the decrepit, outdated PCs. How can we get the printers up...
it's a wireless access point;configure your imacs pc with any pivate ip address like 192.168.1.1/192.168.1.2 etc and don't forget to installed ethernet driver and wireless daemon is on select the authenication protocols as stated in the access point;hope it connect
Dec 01, 2009 | Belkin 5-Port USB Hub
Belkin Wireless 5-Port Hub (F5L009) Problem
If you set the allowed IP address in the security section of the router then you must fix your computer IP to 192.168.1.101 with a subnet mask of 255.255.255.0 the default gateway should still be 192.168.1.1 and when you get in delete the security locking out all but the one address. Good Luck
Sep 03, 2009 | Belkin Wireless USB Hub
Bellkin G+ Mimo usb adapter - invisible
Use this tip as a check list.
Check if you set the correct SSID + Key and "connect if router is not broadcasting" set in your adapter configuration.
If you do not know Key you need to reset from Router.
If you missed SSID you can check on any PC when connected to WLAN and retrieve the name of NON BROADCASTED network
Jan 20, 2009 | Belkin Wireless-G Plus MIMO Router with...
I recently purchased the Belkin Network USB Hub (F5L009) and have hooked it up to my wireless network. I have a multi-function printer and an external Maxtor OneTouch 4 hard drive attached to it. Most of...
http://www.belkin.com/support/ this link might help you. you might have to call them and find out. My solution to this is that if it has done all this in the last month or so i would suggest returning it to the company and buy a different brand. that is just a suggetion
hope this works for you
thanks tazman
Jul 06, 2008 | Computers & Internet
Belkin Wireless USB Hub Logo
279 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
