FixYa.com
Tags:
Jenn-Air 30 in. CVG4280 Gas Cooktop
Ventilation system on Jenn Air CVG4280
posted by yayabobo on Oct 17, 2007
The ventilation system will come on when the grill burner is in use.  It is not suppose to come on when the burner module is in but it does now.  It never use to.  Thanks for any assistance.
Comment by yayabobo, posted on Feb 19, 2008
My drip pan has warped and so the bar on the pan wasn't pushing the level down. I took a pair of plyers and bent the bar down and now the fan does not turn on. Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 16, 2008
FixYa! (100)
Mighty Quinn
Rank:Apprentice Apprentice
Rating: 100%, 3 votes
My Jenn-Air had the same problem. When you install the drip pan for the burner module, there is a "finger" on the pan that is inserted into a hole in the front of the stove. If you look into that hole, you will see a lever switch. The finger on the drip pan on the burner module is supposed to push that lever switch down and turn the fan off, but over time the lever gets pushed down further and ultimately it does not get activated when the drip pan is installed.
You can either replace the lever switch, or you can try to pull it back into place and tighten the two small screws that hold it in place. Actually, I chose a third option and attached a small, flat spring to the finger on the drip pan.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 08, 2008
Not Rated (0)
trum
Rating: 0%, 0 votes
wow, for years turning on the left side burners would start the fan, so I've learned to (gently) slam the drip pan left or right a few times which would eventually turn off the fan. Who wants to pay for a repair that is really just an inconvenience?! Obviously my switch was only a little bit out of whack because, just now, I bent the drip pan finger down less than 1/4 inch and the problem is SOLVED! thrilling!
Solution #3
posted on Oct 18, 2007
Not Rated (0)
fridgetech
Rank:Guru Guru
Rating: 88%, 719 votes
It must have a bad fan relay which you can get on http://www.appliancepartspros.com/partsearch/model.aspx?model_id=42194.  It's under 1. Blower assembly plenum and their part # is AP3990101 and cost is $28.28.  Would appreciate a solved rating for expert advice.  Let me know how it turns out.
Can you Help with these Kitchen Cooktops problems?
Kitchen Cooktops
jenn air elect stove. radiant...
the heating element sometimes... Answer This...
Kitchen Cooktops
DCS range igniter won't stop
After cleaning my range,... Answer This...
Kitchen Cooktops
Bosch Cooktop Thermocouple
I have a Bosch PGL series gas... Answer This...
Kitchen Cooktops
jenn air cook top
I broke the glass cok top on my... Answer This...
Top Right Burner will not...
When I move the top right... Answer This...
Repair Service
Find Kitchen Cooktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
