Question about managemylife.com
Garage door opener 315MHz
Figure 3 page 10 of the manual shows the need for two 4A1008 Master link kits (what appears to be a smaller one and a larger one)but the parts I received do not need two kits -- just one. I suspect that I am missing some parts or... there has been a design change not reflected in the instructions.
I don.t now
Posted on Dec 27, 2013
What is the different between 41AB150-2 and 41AC150-2?
This receiver logic board (part number 41AB150-2) is for garage door openers, including Craftsman garage door opener model 13953904D.
This receiver logic board (part number 41AC150-2) is for garage door openers, including Craftsman garage door opener model 13953901DM.
315MHz Security Radio Controls Purple Learn Button Replacement Garage door opener receiver logic board 41AB150 2 for... 25313039-z4aba1t3xnu0kgnrds04j5va-2-0.jpg
Dec 08, 2014 | Cars & Trucks
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
I bought a new Chamberlain garage door remote control (Model 953EV/EVC) but my garage door opener is date 1991. Can I get this remote to sync with it? I have one remote dated 1993 that came with the...
The 953EV/EVC remote is designed to work with garage door openers at 315MHz (more or less). Your older unit doesn't work at that frequency. I'm not positive but it could be 300MHz.
You need a retrofit unit to use the new remote. See https://aclickawayremotes.com/Liftmaster/355LM-2-315-Mhz-Garage-Door-Opener-Conversion-Kit/index.html for one that works with Chamberlain units.
I hope this helps.
(who has 2 pre-1993 garage door openers and two post-1993 units on various buildings. Yes, we run around with 2 remotes everywhere.)
Mar 13, 2013 | Home Security
My 355lm will accept the keyless only and will lock up when adding the remote what solution would you have
First things first. The 355 Lift Master garage door opener receiver will only accept a limited amount of codes.
You can clear the codes and this will most likely fix your problem.
1.:Clearing the codes from the355lm receiver.
You do this by pressing the learn button on the receiver and hold for 20 seconds.
(The LED light will come on and remain on. Hold until the light flashes. When the LED light flashes, this indicates that the codes are clear.)
You may now release the button.
You are now ready to Reprogram your remotes and keyless entry.
If this does not fix your problem, most likely your receiver is bad and may need to be replaced.
Hopefully this has helped you. Keep me posted!
CarrieSharee
Jun 24, 2011 | liftmaster 355LM Garage Door Receiver...
Sears garage door opener (GDO) model 139.53985D, only a couple of years old. 315MHz remote controls. Opener has stopped responding to the remote controls,unless a remote is held wihin 12 inches of the...
There is no way to change that radio frequency it is set by the government. Sears service technicians have an instrument to help them locate the interference that causes this type problem.
Oct 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener transmitter/receiver compatibility
Press and hold the homelink button and wait till the red light flashes slowly,but don't release it. Now hold a working remote 3 inches away,press the remote button and hold it.When the red Homelink buttom fllashes quickly, release both buttons. Now go to the opener and push the learn button. Now go back to your car and press and hold the Homelink button. You will see the lights on your opener flash. Now your Homelink button should operate your garage door.
Jan 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
managemylife.com Logo
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
