Question about Rival Microwave Ovens
Blows fuse when plugged in
As soon as I plug microwave into wall outlet it blows the 20 Amp fuse
  • 5,348 Answers
There could be something wrong with the mains cable to it. Or it's power supply.
Posted on Dec 27, 2013
fridgetech
  • 473 Answers
SOURCE: Microwave keeps blowing fuse
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
Posted on Nov 19, 2007
  • 833 Answers
SOURCE: microwave stopped working
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9098 Answers
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
  • 11 Answers
SOURCE: microwave blowing fuses
Sanyo isn't that great of a manufacturer.. I had a microwave from them a few years back that did the same thing.. The wiring inside the microwave is shot.. if you were to open it up, you'd probably see some burnt wires from a short. If you use the microwave over a range, it may be because of grease build-up...
anyhow, its better that you invest in a new microwave, rather than fix it. It will be much more cost efficient
Posted on Jun 02, 2009
  • 8909 Answers
SOURCE: tappan microwave over blows 20
Either or both. If the magnetron goes short circiut the the diode wil fail as well.
Posted on Dec 24, 2010
Microwave keeps blowing fuse as soon as plug into wall receptacle.
Just to clarify: With the door closed, the fuse will blow as soon as you plug the unit in? Have you checked all three microswitches? One acts as a crowbar.
Dec 27, 2017 | Microwave Ovens
Microwave blows fuse to kitchen outlet when it is plugged in. microwave still works.
What else in on the circuit? Your oven should be on its own. If you live where I live, this should be a 20 amp 120 Volt AC branch wired directly from your power panel.
If this is not the case, have a licensed electrician install a proper circuit for you.
Mar 18, 2013 | Cuisinart CMW-100 Microwave Oven
I have GE Advantium 120 SCB1001 Microwave Oven. It is plugged in, outlet has power, but nothing comes on at all.
There are TCOs (thermal cutouts) which also can fail or blow, resulting in "no power" conditions.
All but one of them should be accessible without taking the oven from the wall.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The full service manual is here.
You can find helpful exploded views and order GE parts here.
BUT there is one TCO which has thinner wires of a color other than black or white. This is the hood TCO and should read "open" or "infinite" which is correct.
All other TCOs should read shorted or virtually zero ohms on a continuity test, as should the fuse.
The cavity TCO is only accessible by removing the oven from the wall, then taking off its outer cover.
When taking the oven from the wall, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jun 07, 2012 | GE Advantium 120 Convection/Microwave Oven
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Loss of power
yes remove outer cover its a 15 or 20 amp ceramic cartridge type fuse
Sep 21, 2009 | GE Advantium 120 Convection/Microwave Oven
Just quit. No power, no display....nothing
there are several possible causes, check voltage at outlet
check the 20 amp bus fuse on the main board ohm out the cavity thermostat, replace the bad part
Sep 10, 2009 | Samsung MS1040BB Microwave Oven
No power!
There's an internal fuse - about 20 Amps. It usually blows when the magnetron dies. Unplug the unit from the wall and access the internals. You should plainly see the fuse holder - remove and check the fuse. Spares are available at any ACE hardware store. If the unit is more than 5 years old, I wouldn't mess with it.
May 24, 2009 | LG LRM1260SW Microwave Oven
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
Emerson microwave
microwaves need to be on a electrical circuit that serves nothing else but itself, one quick way to see if this is the problem,unplug your refrigerator and plug the microwave in and see if its ok plug-ed in that plug, if it is you will need to find another plug else where that has nothing else on it, and it should be on a 20 amp-her circuit, like the frig. (in most cases), hoped we helped,good luck to u..
Mar 12, 2009 | Emerson Black Microwave Oven
Nov 19, 2007 | Microwave Ovens
Microwave Ovens Logo
59 people viewed this question
Top Rival Microwave Ovens Experts
William Miller
William Miller
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Rival Microwave Oven Expert? Answer questions, earn points and help others
