Question about Lenovo G530 Notebook
Blank screen Black Screen, it won't show anything at start up, not even the lenovo logo. any help, please
  • 383 Answers
SOURCE: Blank screen
Dead or black pixels. Information about dead or black pixels on a lcd or computer display. ... Determining how many dead pixels are on the screen .
E-mail CHID: 5858 All it says is Error loading operating system on a black screen. Answer. This issue is often caused when the computers BIOS.
Read & Follow instructions/ Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 23, 2007
freddygon66
  • 93 Answers
SOURCE: my lenovo n200 does on turn on it beeps and screen remains blank
Hi, you must remove both memories and return to wear them in the socket, it is for it that your equipment not power on correctly
Posted on Jan 20, 2009
joecomputer
  • 92 Answers
SOURCE: lenovo Y510 stuck on logo screen at startup
Your hard drive maybe failing. I would make a back up as soon as possible . Then I would do a dskchk, Here's how:
Double-click My Computer, and then right-click the hard disk that you want to check.
  1. Click Properties, and then click Tools.
  2. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  3. Use the following procedures:
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer? Click Yes to schedule the disk check, and then restart your computer to start the disk check. Please don't forget to rate this solution.
Posted on Jun 13, 2009
shynysaxena
  • 166 Answers
SOURCE: Lenovo ThinkPad and a blue screen
Sir this is due to Hard disk internal problems and you will need to perform PRIMARY HDD test by using BIOS setup wizard.
Posted on Jul 21, 2009
SOURCE: my lenovo t60 screen goes black 15 seconds after
Hi, try to boot into safemode, turn your system on then keep on tapping F8 to get the windows advance Menu screen, select safemode.
In the safemode windows go to Control panel and check your power options, you will see what time frame your system has for the LCD when turning off.
If this does not fix the issue, try booting into safemode with networking for you to be able to go online in safemode try updating your BIOS from your Manufacturers Website, Updating your bios may fix the issue.
Posted on Sep 28, 2010
Lenovo s100 driver
Try pressing F8 just before it tries to boot. If you can get to safe mode you may be able to recover the damaged Boot Manager Files.
May 25, 2014 | Computers & Internet
Shows nothing but a blank screen. Does not even show the lenovo logo. Lenovo R51
Hook the laptop to an external monito, to see if you get video. If you do, then it is your LCD screen that is out. If you don't, you may be looking at a problem on the system board.
Dec 07, 2010 | Computers & Internet
Screen is blank (white) when turned on.
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Turn off the system. Unplug the power cord from the mains. Keep the power button of the cpu (not the monitor) pressed for 5-6 seconds. turn the unit bcak on and check.
Please reseat the monitor cable that connects to the desktop ensuring a secure connection.
Further, if you are able to see the Lenovo Logo on startup try booting to safe mode by tapping F8 key on the lenovo logo itself.
Howevre, in case you are not even able to view the lenovo logo on startup, then it could be a fault with the lcd monitor itself requiring a repair.
Nov 17, 2010 | Lenovo L191 (Black) LCD Monitor
Ibm t61 turns on but all I get is a blank black screen.
This sounds rather bad. You're not even getting a "thinkpad" screen?
Try unplugging the power and removing the battery for a minute and attempt to power up again.
If it's still not starting, try removing the memory modules (if there are two, remove one and try powering up, then try to remove the other one). Although I seem to remember that newer thinkpads will still show thinkpad logo and attempt to POST even with bad memory (then throw an error), it's always worth a try.
If the above don't make any difference then I'm afraid most probably your motherboard has failed. In theory you could also try swapping the cpu-I've seen a cpu go bad ONCE in my several years of tinkering with laptops.
T61 is a current model-wouldn't it still be under warranty from lenovo? Might be worth checking the serial on their website. Otherwise it's time to search for T61 donor laptops on ebay - ordering a new motherboard from lenovo parts suppliers will most probably be far too expensive.
Good luck, hope you get it working again!
Raf
Nov 09, 2009 | Lenovo ThinkPad T61 Notebook
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Black screen when i play resident evil 5
What firmware are you running?
Sounds like corrupted game data to me.
May 13, 2009 | Video Game Consoles & Games
Blank screen with cycling colours (no BIOS; no POST)
Try running diagnostics. Tap F12 repeatedly on the dell logo till you get the boot device menu. Choose diagnostics. Go through it.
If it doesnt even pull up the diagnostics, you can follow this walkthrough from dell's website.
Oct 04, 2008 | Dell Precision M60 Notebook
Blank screen
Dec 22, 2007 | Lenovo ThinkPad T61 Notebook
Lenovo G530 Notebook Logo
21 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
