Question about Dishwashers
My LHBO8100085 runs on/off all the time is that normal?and is 7 the highest setting?
650 dual pump holley carb 4 barrel
set idle at idle screw to around 700 rpm, then adjust the two air mixture screws, one at a time, by slowly turning in (not tight though!) until the car wants to stall out, then back it out until you have the best, highest idle-do both sides, you may have to do them a few times. An electronic tach hooked up to the negative side of the coil can help so you do not have to depend on sound, or a vacuum gauge is very helpful, aim for the highest vacuum you can get. After you get a smooth idle, double check overall idle setting and keep it close to 7-750 rpms.
Apr 07, 2014 | 1966 Chevrolet Corvette
5570 128bit
This is 32bit color depth and is the highest / normal mode for these cards. The cards hardware is running with 128bit bandwidth which is a memory timing issue and you will not see unless you use a program such as GPUZ. They are 2 completely different things.
Check it out here:
http://www.techpowerup.com/gpuz/
Aug 26, 2013 | Power Color POWERCOLOR AX5570 512MK3H...
Heat/ac on works on highest setting
Sounds like the blower motor resistor is no good. Easy to change it.
Mar 17, 2013 | 1997 Dodge Caravan
Frigidaire model FFU17M8CW1. Top shelf iced up and low temp light came on. Compressor ran continuously. Emptied the freezer and defrosted it. Not for very long...just long enough for the ice to melt, wiped...
The shelves are the evaporator in your freezer. It is normal for the shelves to have frost on them. The more moisture in the unit the more frost you have till you have to defrost it like you did. The fact that only one of your shelves is frosting indicates that the system is low on freon. Must have a leak which requires a qualified havc to find and repair. The temp in a freezer should be between 0 and 10 degrees. At this point your compressor is keeping it cold only by running all the time. As more freon leaks out the temp will rise. This may occur slowly or at a quicker rate depending on the amount leaking.
Aug 24, 2011 | Frigidaire Kitchen Ranges
When setting the coldness in the refrigerator where shoud the setting be at if the range in numbers is 1-7? What is the most common setting?
Good day,
The normal settings on any refrigerator is half way between the the lowest number (warmest) and the highest number (coldest).
In your case that would be 3 1/2.
However, on your model 4 is the setting most often used.
May 08, 2010 | Kenmore Refrigerators
Not optimum mode
This means that your resolution (the amount of pixels) is not the same as your monitor's recommended setting.
The easiest way to fix this is to go into your display settings (right click your desktop and, if XP: Properties->Settings or if Vista/7: Screen Resolution) and drag the slider all the way to the right (XP) or top (Vista/7).
If the highest setting makes your screen go blank for more than 5 seconds, press Esc and try the next setting down. Do this until your monitor correctly displays the highest setting allowed.
Mar 27, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
Screen will flicker a few times at random periods
Change the display resolution in Windows Change the display resolution to the highest resolution using the following actions:
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, the notebook display might need servicing.
Feb 13, 2010 | HP Pavilion dv4000 Notebook
Have a Zanussi ZCF132 Chest freezer. In normal mode the freezer has ceased to freeze even with setting to highest position i.e. 7. However when the super freeze switch is pressed it does as described,...
sounds like the thermostat.when you engage the super freeze button you merely bypass the thermostat to enable full time running of the freezer this is all the superfreeze button does
Aug 12, 2008 | Refrigerators
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
