Question about Motorola Mobility PEBL U6 Cellular Phone
Internal speaker won't power back
When I power my phone on, everything works fine. If I leave it for a few minutes and the screen shuts off, when I activate it again the internal speaker no longer works; the buttons don't make a tone, nobody can hear me if I respond to an incoming call, etc. I've tried switching off battery management and screensavers to see if this helps, but it still shuts down and gives me the same problem.
  • 94 Answers
Rite .... well i suggest you find a new battery about 2 or 3 pounds of ebay and then try . if this still doesnt work then i would take it to a shop and have them to look at what the problem is they shouldent charge you just ask them  to look at it , then whatever the problem is you could get the answer of here . Hopefully this helped you.
Posted on Oct 17, 2007
IPhone 4S shuts off randomly.
download itools get the latest one in the software there is system check crash report have a look on that it will tell you everything your phone is not doing, also when you install a new battery make sure the battery is flat, the screen should of come up with red line some batteries have charge in them and this can confuse the phone, another thing you can do is backup phone and do dfu setup, ios 8 sometimes has a problem and will need to be reinstalled new only do this in dfu mode, connect phone to pc etc and hold down the power button and home when the screen goes blank count to 6 seconds and then release the power button but hold down the home button for about 10 seconds or longer or until you hear the pc beep and install the dfu drivers. itunes will say that the phone needs updating do that, when finished don't do the setup , leave it for a few minutes then turn off phone leave off for 6 seconds then turn back on and continue with the setup it should be fine then, failing this and it still does this then the charging chip needs to be replaced, this is not a job for the layman need to be done professionally. hope this helps.
Mar 18, 2015 | Apple iPhone 4S
Arcam avr-250 shuts off?
New problem?
Did you move it recently? Sometimes the speaker wires are stripped too long and short out against each other in the back
Disconnect EVERYTHING from the unit but please take great care to document how everything is connected so you can connect it again the same way.
IF the unit powers on fine with everything dis-connected, I can assume that you have a connections problem with the speaker wires being the most likely culprit.
Make sure your speaker wires are not stripped too long where bare copper is touching other terminals OR make sure the speaker wire is pushed cleanly into the speaker connections without stray wires to cause a short.
Also make sure you have the speaker wires connected to the proper terminals and are not mis-wired into the wrong terminals.
IF it still shuts down after a few seconds with nothing connected then there is an internal problem that will need to be repaired.
Good luck.
May 28, 2014 | Audio Players & Recorders
Screen goes black after 30 mins of working.
There are a few things you need to check here.
1. It could be that your computer power management is set to turn your monitor and harddrive off after 30 to 45 min.
If the computer is however working for 30 to 45 min while you doing stuff and it shuts off, the there is an internal problem "Hardware"
I would suggest you check to see if the power management is set to turn off monitor 30 min and harddrive after 45 min. IF that is not so, then we go on to the next test.
It could possibly be your processor fan is not working so once your processor gets over heated it shuts off the computer.
Turn off the computer, remove the case "this is only if you know what you are doing" with the case off, power on the computer and see if the processor fan is working.
You can get back to me and I can walk you through it.
Hope thiss help.
Aug 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Yamaha HTR-6130 Receiver will not stay on! Shuts
One last try with everything disconnected!
Other than that I suspect internal surge damage.
Aug 04, 2009 | Yamaha HTR-6130 Receiver
Power turns off
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 31, 2009 | Samsung HT-X50 System
Unit shuts itself off after 10 -15 minutes
Bad speaker wiring.
Internal fault.
Regards.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Protect mode shuts down the receiver
If this happens only when connecting the receiver, chech the receiver cable. If the cable is fine, receiver connector at the back of receiver is faulty.
Bad speaker wiring.
Internal fault.
Regards.
Dec 23, 2008 | Samsung HTZ-510 Theater System
Treo 755p (Sprint) Will not pull power from battery or AC
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=56,E=0000000000825376672,K=2082,Sxi=19,Case=Obj(30029)
Depending on how old or new (maybe a bad battery from factory), this is the only thing I found related -
My battery loses its charge very quickly
Like all Lithium Ion batteries, the battery in your device will eventually wear out. If you charge your device fully but it loses power after a few hours (or sooner), it may be time to replace the internal battery. Arrange for a repair.
For best results, don't let your battery fully drain before recharging. Lithium Ion batteries last longer if you "top them off" frequently.
Jan 06, 2008 | Palm Treo 755p Smartphone
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Motorola Mobility PEBL U6 Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
