Question about Microsoft Xbox 360 Console
How to reset dashboard 2.0.16547.0
IP:70.124.13.216:3074
How do I open a xbox portal
here ya go, this is on the latest updated dashboard!
In the Xbox 360 Dashboard:
  • Go to My Xbox and open System
  • Select Settings
  • Select Network Settings
  • Select Configure Network
  • On the Basic Settings tab, select the IP Settings area
  • Select Manual
  • Next, select IP Address
  • Type in the IP address you have chosen and select Done
  • You should be looking at the Edit IP Settings screen. Select Subnet Mask
Oct 14, 2014 | Microsoft Xbox 360 Console
Need ip adress for xboxlive/360
on the xbox dashboard go to my xbox, system settings, console settings, then highlight system info. It should show you the xbox's ip adress.
Feb 04, 2011 | Video Game Consoles & Games
TENGO UNA COPIADORA IR3220 COLOR QUIERO SABER COMO SE CONFIGURA LA IP ADREES YA QUE QUIERO AGREGARLA A MI RED
additional functions on the dashboard
system settings
network settings
tcp-ip settings
Sep 13, 2010 | Canon imageRUNNER C3200 Copier
Connection to winows media failed
1. check your netwok calble properly
2. check your router internet connection
3. follow these steps
Accessing network settings loadTOCNode(2, 'moreinformation'); To access the Network Settings area, follow the steps for the version of the Xbox 360 Dashboard that you are using.
New Xbox Experience Dashboard:
  1. From the Xbox 360 Dashboard, select System Settings in the My Xbox area.
  2. Select Network Settings.
  3. Select Configure Network.
Legacy Xbox 360 Dashboard:
  1. From the Xbox 360 Dashboard, move to the System blade.
  3. Select Edit Settings.
IP settings, IP address, subnet mask, and gateway loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this imagenetworksettings-basic.jpg
After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the IP Settings block, you are prompted to select an Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your IP settings from your network or from your modem or Internet service provider (ISP). This option is recommended for most users.
You may have to or prefer to manually configure the IP settings, especially when a static IP address is used. This is necessary only if your ISP has issued a static IP address, or if you have configured the router to issue static IPs (and DHCP is not used). To manually configure the settings, select Manual, and then enter the IP Address, Subnet Mask, and Gateway by using the keyboard on the screen. When the information is complete, select Done.
DNS settings, primary and secondary DNS servers loadTOCNode(2, 'moreinformation'); After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the DNS Settings block, you are prompted to select Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your DNS settings from your network or from your modem or ISP. This option is recommended for most users.
You may have to or prefer to manually configure the DNS settings, especially in scenarios in which a static IP address is used or where DHCP is not available or not offered by the ISP. To manually configure the settings, select Manual, and then enter the primary and secondary DNS server names by using the keyboard on the screen. When the information is complete, select Done. Note You do not have to enter a secondary DNS server to connect to Xbox LIVE. A secondary DNS server is required only if the primary DNS server has technical problems.
Wireless settings loadTOCNode(2, 'moreinformation'); To configure your Xbox 360 console to connect to your wireless network by using an Xbox 360 Wireless Adapter, follow these steps:
  1. Access Network Settings .
  2. On the Basic Settings tab, select Wireless Settings.
    Note If the wireless settings area does not appear or is unavailable, click the following article number to view the article in the Microsoft Knowledge Base: 909333 (http://support.microsoft.com/kb/909333/ ) While attempting to view the settings for a wireless network connection, all the wireless functions appear to be disabled in the Xbox Dashboard
  3. Follow the instructions to select your wireless network, select your wireless network name, and then enter your wireless security information.
  4. Select Done.
PPPoE settings loadTOCNode(2, 'moreinformation'); If your Internet service provider uses PPPoE authentication, you have to enter the settings in the Xbox Dashboard if you have a direct connection through a modem. If you use a router or a gateway instead, leave the PPPoE settings blank because the router performs PPPoE authentication. Note If your ISP does not use PPPoE authentication, make sure that these settings are blank. To learn whether your ISP uses PPPoE authentication and to learn the correct PPPoE information, contact your ISP.To configure the PPPoE settings on your Xbox 360 console, follow the steps for the version of the Xbox Dashboard that you are using.
New Xbox Experience (NXE) Dashboard:
  1. Move to the System area of the Xbox Dashboard by using one of these methods:
    • Press the Xbox Guide button on your controller to open the Xbox Guide, scroll to the right to access Settings, and then select System Settings from the list of options.
    • Select the My Xbox channel, and then scroll to the right to select System Settings.
  4. On the Additional Settings tab, select PPPoE Settings.
  5. Use the keyboard on the screen to enter the PPPoE information that was provided by your ISP.
  6. Select Done.
  7. Select Back to return to the main Network Settings area.
  8. Select Test Xbox LIVE Connection to restart the test with the new PPPoE settings that you have configured.
sure it will work thank you
Mar 14, 2010 | Microsoft Xbox 360 Console
How do i set up xbox live
  4. Select Done.
  6. Select Done.
Feb 11, 2010 | Microsoft Xbox 360 Elite Console - Black
My xbox 360 console does not save my ip address
Are you using a router? Or are you hooked up directly to high speed internet? If you don't have a router, you might look into buying one, they run about $50. If you have a router, in the settings on your Xbox choose DHCP under your network settings. This way your router will automatically give an ip address.
Hope this helps,
81
Nov 30, 2008 | Microsoft Xbox 360 Elite Console
HiWhen you attempt to access Microsoft?s Xbox Live
If you have a home network (router) try resetting it. Make sure you reset your console at the same time. You can try resetting your modem. Once you reset either give it 2 mins. to come up. Hope this works, if not contact you ISP (internet service provider).
Jun 25, 2008 | Microsoft Xbox 360 Console
Change NAT to open
I don't have your Internet connection details or OS
so we'll start from the beginning:
1.Log into the router and under the Setup tab click on "Setup Wizard" then on the next page click on "Launch Internet Connection Setup Wizard" In step 1 leave the password unchanged and click next. On step 2 select your time zone. On step 3 this is important; select your Internet connection type. On the 4th step leave the Address Mode in Dynamic and enter the username and password supplied to you.
Once you have configured your Router to work with your Internet connection type, you should now get a Moderate reading when you do the Network test in the Xbox dashboard.
2. Now go here http://www.portforward.com/networking/static-xp.htm and follow the instructions to setting up a static IP address on your computer.
3. After setting up a static IP address on your computer, go here http://www.portforward.com/english/r...x_Live_360.htm and follow the instructions. Something you should keep in mind which isn't mentioned on this page is, for each port you forward under the box that says "IP Address", don’t put the IP address of your computer, you put in the new IP address of the Xbox 360 which was one of the 5 that was generated from that link in step 2. What you are doing is giving the Xbox 360 a new IP address and that new IP address needs to forward these port numbers to the Router.
4. Go into the Xbox dashboard and edit the Network settings. Under Basic Settings click on IP address and set it to manual. Now enter in the new IP address you chose for the Xbox 360. The subnet mask and the gateway is the same as your computer. (You can find these by clicking start> run> type in ‘cmd’ then when the box comes up type in ipconfig/all
Under the DNS Settings it should be set to automatic and under Additional Settings leave them empty. Run the test in the dashboard and it should now be Open!
Feb 23, 2008 | D-Link 802.11g Wireless Router WBR-1310...
I cant get an update for xbox live
first try resetting your connection, unplug your modem or router for 30 seconds and see if you get a connection. after that it would be a software issue. more likely its failing to update because you have NO internet signal. try also, re-configuring your network IP settings which is usually automatic- with no disk in or through the dashboard. if you can get into dashboard try manually putting these in.. but like i said try unplugging your modem for at least 30 seconds to update the IP. good news... if microsoft has to repair it theres a good chance youll get a brand new system though it might take a few weeks at least. is this with a brand new system?
Dec 20, 2007 | Microsoft Xbox 360 Console
Xbox live
THINGS TO TRY loadTOCNode(1, 'whattotry'); Direct connection with a modem only loadTOCNode(3, 'whattotry'); 1. If you are connecting to Xbox Live by using a modem that is connected directly into your broadband socket, your IP address settings are obtained from your ISP. Set your IP address in Network Settings to Automatic. 2. If you use a static IP address that you obtained from your ISP, you must manually enter this address in the Dashboard. Contact your ISP for their static IP address if you do not know it. If the IP is not static, continue with the rest of the troubleshooting. 3. Power cycle the modem. 4. If your ISP requires PPPoE settings, verify that you have entered them correctly. 5. If your ISP does not use PPPoE authentication, do not use these fields in the Dashboard. Shared connection with a modem and a router loadTOCNode(3, 'whattotry'); 1. Power cycle both the modem and the router. 2. Try connecting the Xbox 360 console to Xbox Live by using the modem only. This eliminates any configuration problems on the router. • If this setup works without the router, there is a configuration issue with the router. See the router's documentation or contact the technical support group. 3. Verify that your router's DHCP service has been enabled. See the router's documentation or contact the technical support group. 4. The IP address that you entered in the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If your ISP requires PPPoE settings, try to connect with only the modem after you enter the PPPoE settings in Network Settings. • If you can connect, see your router documentation to configure the PPPoE settings correctly on the router. 6. If you are receiving an IP conflict error in the More Info section, turn off all the devices on the network. Try to connect with only the modem and Xbox 360 console connected. • If this works, there is a configuration issue on the routers DHCP server. See the router's documentation or contact the technical support group. Shared connection with a gateway device (combined modem and router) loadTOCNode(3, 'whattotry'); 1. Make sure that the device is turned on. 2. Verify that there is activity with the blinking lights sequence WAN, ADSL, and Internet connected power. Note These names will vary from model to model. 3. Power cycle the gateway device. 4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If you are receiving an IP conflict error in the More Info section, turn off all the other devices on the network. Try to connect with only the Xbox 360 console on the network. • If this test works, there is a configuration issue on the gateway DHCP server. See the router's documentation or contact the technical support group. Shared connection with Microsoft Windows Internet Connection Sharing loadTOCNode(3, 'whattotry'); 1. Verify that you can browse the Internet. If you cannot browse the Internet, Internet Connection Sharing is not configured correctly. 2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer. 3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK. 4. On the View menu, click Tiles. 5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation. 6. Enter manual settings in the Dashboard for IP address, subnet mask, DNS address and gateway: • IP Address : 192.168.0.2 • Subnet mask : 255.255.255.0 • Default Gateway : 192.168.0.1 • DNS server (Primary): 192.168.0.1 • DNS server (Secondary): 192.168.0.1If none of this works you might be banned. If you modded your xbox360 or for downloading game saves from the internet to boost you gamer score. You might be banned!
Oct 14, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
455 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
