Question about Emerson EMSEM2646WH Phone
Adjust how many rings
How do i adjust the number of rings for incoming calls
Incoming call ring just once
ring settings ---repeated
May 28, 2015 | Lands Phones
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Dell 2135CN cuts-off incoming calls to my home phone number after 2 rings and the call goes to the printer. I hear the ringer inside printer, then hear fax tones, even though the call is not a fax. My...
Hi and welcome to FixYa!
Well if that's the case, the printer should be detached or powered of during call operations. The printer detects incoming calls that's why it triggers it to operate. Turning it off during operation will surely be the solution.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 05, 2011 | Computers & Internet
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
My phone only rings 3 times for incoming calls
There is no such option in motorola as i know to extend duration of incoming ring.
Apr 28, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Sony Ericsson z750a incoming rings end too quickly.
cancell all call diverts. it may be happening due call diverting.
Jun 04, 2009 | Sony Ericsson K750i Cellular Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
I want to increase the number of rings for incoming calls please
i think there is a particular limit. you cannot increase the number of ringing.
Jan 18, 2009 | Nokia 6131 Cellular Phone
Emerson EMSEM2646WH Phone Logo
12 people viewed this question
Top Emerson Lands Phones Experts
Computer Repairing
Computer Repairing
george  peters
george peters
Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
