Question about Lakewood Engineering&Manufacturing PHT150 Space Heaters HEATER,PERSONAL
Model 792/A 1300/1500 watt space heater. Heater
Model 792/A 1300/1500 watt space heater. Heater coils will not heat up and the fan will not spin.
3 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: Hello, I have a Lakewood space heater, Model #
The heater "over-heated". It's supposed to have a safety cut-out. The question is, can it reset itself? If there is no manual reset button on it, leave it unplugged for 30 minutes or so. If it still doesn't work, spend $20 on a new one.
Posted on Jan 19, 2010
timobrien15
The heater is equipped with a thermal fuse. Replace that and it will work like new.
Posted on Nov 16, 2014
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Tip
How to heat a garage or workshop
Two things to consider in buying a space heater - the require BTU and the electricla cost to heat your space.
You can go here to calculate your estimated BTU need - http://www.calculator.net/btu-calculator.html
or just look up "BTU calculator' on line and there are other BTU calculators as well.
The BTU is what is pretty much required to effectively and efficiently heat to the temperature range you are comfortable with. It's a matter of the maximum degrees you want to raise the temperature. In my case I wanted to be able to increase the ambient temperature in my woodworking workshop from 40 degrees to 65 degrees and I have less than favorable insulation in this workshop, so my desired BTU is 16,359 at 4,794 watts. This heater meets that demand quite nicely.
As for cost, as I mention in the video (link above) the two ceramic space heaters were costing me about $1.56 per evening to heat my workshop. This heater is costing me only about 92 cents for the same length of time. I have immediate savings of over 62 cents per evening of use! Why the huge difference? Because the other two space heaters had to run continuously at combined 3,000 watts for 2 hours to heat the space and then continuously to maintain the desired temperature. The Dr Heater DR966 bring s my workshop from 40 to 60-65 degree in a half hour at 6,000 watts and then only runs intermittently at 3,000 watts to maintain that temperature. Therefore I am using less electricity to heat my shop to 65 degrees and to maintain that temperature.
I have my heater connected to a 30amp circuit breaker and have had no issues with the electrical demand of the heater tripping the breaker. But I am also using a six-foot long 6-gauge cord from the heater to the outlet and 8-gauge wire from the outlet to the breaker and the outlet is mounted directly underneath the sub-panel, so there virtually no distance from the breaker to the six-foot cord.
If the BTU supply of this heater meets your BTU demands I recommend that you get this heater and see for yourself what it's like to have a well heated work space. It's nice!
Here's a link to view the heater I used.
http://astore.amazon.com/wwwdogwoodtal-20
on Jan 28, 2016 | Heating & Cooling
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
My Patton PUH680 space heater is not working. Do you offer replacement coils?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Dec 06, 2010 | Patton PUH680-U Utility Heater
I have a 724 heater7500 w 28x32x10 garage with dog door it will only keep garage at 40 degree not 50 like i want in minnesota what are my options
The heater is too small for the space you are heating....
You need to get a second heater or get a bigger heater to get more heat...
Heatman101
Nov 30, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
Small Rival heater ... 1500 watts... model # T620/1 serial # 11-27 I love this small space heater.... but I've had it so long that the setting decals have worn off. I need to know where the heat/fan/...
Heh, I just went searching for mine because it was getting cold. The left knob is (from left to right) Hi, Lo, and Fan Only. The right knob goes from Off on the bottom left to Hi on the right. It doesn't click or anything, since it's the one controlling how hot you want it to be.
Oct 22, 2010 | Heating & Cooling
I installed a 1000 watt four foot long Farenheat F2544 baseboard heater in my outdoor workshop. But it's too small for the space. I calculated that I probably need 2000 watts to heat my space. But I do not...
I could find no electrical code or mechanical code that says you can do that, so I wouldn't do that.
But have you thought of or do you have the overhead space to install a hanging unit heater? They don't require much space(just make sure you install it per manufacturers specifications) and they come in much higher BTU ratings.
Nov 23, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Electric baseboard heater
this is a tough call but with 2000 watts in each room there should be more than enough heat .the rooms should maintain a average temp of 73 to 78 degrees temp without weatherazation and that is of course there is no drafts coming from any windows or near a front or back door that opens and closes alot . Basiclly you have it covered but definatley get the house winterize/insulated real good.I would keep 1 or 2 space heaters on hand just incase the person in house feels there cold just to cover yourself ,usually it the female complaining its cold if its not warm enough but there have been some males that need that temp to be 80 degrees all the time.good luck but im sure it will be ok!!
Sep 29, 2009 | Fahrenheat Electric Convector Baseboard...
Electric space heater contactor won't stay latched
Jumpered the bimetal thermostat and everything worked smoothly. Tried to clean contacts in thermostat with no luck, so ordered a replacement. At least it was cheaper than the contactor.
Dec 07, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Lakewood Engineering&Manufacturing PHT150 Space Heaters HEATER,PERSONAL Logo
332 people viewed this question
Top Lakewood Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Lakewood Pool and Spa Expert? Answer questions, earn points and help others
